For those w/ 'Bling" UCA's
Old 01-10-2007, 11:00 AM
terryjmatthew's Avatar
If you had it to do over again, would you still buy them or would you buy the "Schaefer" shaved-arms? I am currently running DR extended coilovers w/ the stock arms and am getting ready to upsize to 35's.
I understand that I will not be able to utilize the extended length of the coilovers with shaved arms, but I am already grenading CV's due to the extra travel.
I am not looking to start any drama over this. If you don't have 1st hand experience, please don't interject your opinion.
Thanks
Old 01-10-2007, 03:27 PM
Jonathan's Avatar
In retrospect, I probably would have just gone with the shaved arms, but my ATS have been great, plus they just look so damn cool.
Old 01-10-2007, 07:04 PM
BruceTS's Avatar
All I'll say is you'll need limit straps, otherwise you'll eventually gernade your upper ball joints, if you wheel it....
Old 01-10-2007, 07:15 PM
d0ubledown's Avatar
i dont understand this part what do you mean by extended length coilovers? is it something specific to 'hoes? or are you just referring to the length you get by cranking em up? im running fagtech basic CO's, and they're fairly cranked, but not maxed out. i dont have any issues with my stocker arm hitting. how would running shaved arms affect your coilovers? the inner "A' is the same isnt it? just the outside has less material.
i havent had any grenading CV's yet (knock on wood), and i wheel it pretty hard (at least i like to think i do ). just put on my 35's, but am using spacers till i figure out the uca situation. havent wheeled it yet, but its tight up in there... gonna have to find me a biggerFH to massage the pinchwelds... and perhaps get some limiting straps as well...
i'd go for shaved arms if i had the choice...
Old 01-10-2007, 08:07 PM
RobT2k's Avatar
I also have the ATS/Inland A-arms, up until now they have been fine. But I just noticed that the bushing on one side of the A-arm has come out of its socket about 1.5", this is causing the whole arm to move because there is nothing stabilizing it on that side besides the long bolt that attaches the upper arm.
I can't remember if the bushing was 2 piece or if it was just 1, I think it was just 1, so that means it has probably broken in half.
Anyone know where I could find replacement bushings?
I don't even know if Inland is still up there in Murrieta.
Old 01-10-2007, 08:13 PM
calrockx's Avatar
I'm not familiar with that arm, but if it's anything like mine there are four bushings- one per half of each side. I got some replacement bushings direct from Camburg, maybe you could try Kartek Off-Road.
So yeah, I've got Camburg UCAs. I've been happy with them. I'd go that route again.
Old 01-11-2007, 08:45 AM
Sonny,
The extended length CO's allow for an inch more down-travel (from what I understand) when used in conjunction w/ aftermarket control arms. The benefit to using the shaved arms is the ability to run a wider tire w/o changing wheels, but that can also be accomplished w/ aftermarket arms. There is no actual inteference b/w the UCA and coilover.
Old 01-11-2007, 04:56 PM
Anyone else?
Old 01-11-2007, 05:51 PM
BruceTS's Avatar
If you run stock or shaved UCA's with the extended Hoe's the stock ball joint will bind at full extention, unless you run limit straps. In which case you lose the extra travel from the CO's. To get the extra travel you must run after market UCA's Camburg or Total Chaos your choice.....
scuba
12-11-2009 06:30 PM
toyospearo
11-13-2008 08:34 PM
Jackal
09-19-2008 11:22 AM
Mikestang
01-07-2007 02:33 AM
sbechtold
11-05-2006 07:28 PM
Quick Reply: For those w/ 'Bling" UCA's
