those with '03 runners, tire pressures
what are you guys running for front and rear tires pressures? the door jamb and the manual tells me 32 front and rear and the sales stooge made it a point to tell me "32" and showed it to me in the manual so that the "free tires" thing wouldn't be voided. only prob is that I checked the pressures this morning when the rubbers were cold and the stealership seems to have inflated the things to 42!! I want to air it down to 32 like the manual/jamb/sales stooge said but, well, if they start to wear funny I will experience the "wrath-of-wife" for my meddling. I guess this is where the modding starts, first the tire pressure, then the ride height, then... "I swear honey, I just want to "fix" this for you so the thing runs better!" we all know were this obsession leads...
The optimum tire pressure can be found by putting chalk across the tread. Drive around the street and see if it is equally removed across the tread. Only missing in the middle then take some air out. Worn more on the edges then add some.
You can also drive through a puddle and see if the tread you leave on dry pavement is even. I don't think it is as accurate as water caught in the voids will run down on the tread but it gives you an idea. I judge how my tires are inflated by how easily the truck accelerates and how well it responds to bumps.
Re: those with '03 runners, tire pressures
Mine came with the Dunlop AT20 POS tires. I checked them cold the day after I got it and the pressure all around was 35 psi. Someone had a thread going back around Feb/March, maybe JGage or impulsebrklyn that they had experimented quite a bit with different pressures and that 38 psi was the best.
I filled mine to 38 and immediately noticed a slightly stiffer ride but I have left them at that pressure. 37.5-38 all around right now COLD.
Later Dude.
ok. thanks. being as it's the wife's and she wants to try to get the free tires when these wear out I'll keep it at 32 psi since that's what it says in the door jamb and in the manual. We have the dunlops on the 17" "rilms." thanks again.
You can't just let some air out every time you go to the dealer? You'll be burning more fuel and acceleration is affected. Only benefit I can see is that its easier to air down off road - you'll air down quicker and you won't put as much air back in after your done.
...I checked the pressures this morning when the rubbers were cold and the stealership seems to have inflated the things to 42!!
The door jamb number of 32 is an excellent starting point. Start from there, and use the methods shown here to make minor adjustments to that.
I’ll take the Toyota recommended 32 lbs over what a stooge salesman says or what a lazy apprentice mechanic puts in the tires any day.
Tom
anything over 40 and u'll definitely see wear on the center... not a good thing...
anything under 30 and u know what you'll get. currently I'm running 36 and seems to be wearing down evenly
Hopefully I won't have to stay in these dumbflops much longer... hehe
I had 38 in mine for a while... Then one day I was checking my air pressure and noticed that the tires said: "35 psi MAX." I run them at 35 psi now.
I'm going to try that chalk test, that is a really great idea.
38 f/r. Gives the truck a much more stable feeling, handles corners much better than when it was at 32 f/r the day I picked up up at the dealer.
-Scott
p.s. - I was fortunate enough to get a Runner with the Michelins
-Scott
My pressure was pretty high from the dealer, well into the high 40's low 50's, cant remember exactly. So, I set them to the 32 as is printed in the door jamb. I figure Toyota knows where they should be set at and I will trust that number.
Hi guys...I have a 03 V6 with 17" rims but the door jam lists a pressure of 32 for 16" not 17" rims..
Can someone with 17" rims tell me what pressure is listed on the door jam for 17" rims.
Thanks a million
http://home.nycap.rr.com/baje/cam9.jpg
Thanks a million
I run 32 psi.
I had my oil changed at the dealer yesterday. The monkey who was helping the oil change guy just started filling up my tires while it was on the rack. While not even checking the pressure, and I had just driven 15 miles! I jumped the restraining barrier to the shop and told the guys to never touch my tires. They NEVER set the right pressure. Even when delivered new, the pressure was out of whack.
Do these shop guys at the dealership even take a High School auto tech class to learn the proper mechanics of tire pressure?
Originally posted by Sac State
I run 32 psi.
I run 32 psi.
careful dude, I think there's at least one of those shop guys that hangs out here.
