There's no such thing as a stupid question.....
Old 04-25-2003, 06:20 PM
amorphous's Avatar
Question There's no such thing as a stupid question.....
ok, I'm running the risk of sounding stupid in cyberspace.
What/how should 4 low function?
what speeds it this gearing for? Does it shift thru all 4 gears normally (in an auto trany situation)
pls,keep in mind, I got my '98 TODAY. Bare with me!
thanks a bunch,
stupid ole me
Old 04-25-2003, 07:25 PM
EOD30's Avatar
4 lo generally is used when you need maximum traction. It is used at very slow speeds, something like less than 15 mph. For example your climbing a semi-steep slope with rocks and other obstacles, you would want to go slow.
If you look in your owners manual, it should give you the max speeds in each gear, 2 hi, 4 hi, 4 lo.
Hope this helps
Mat
Old 04-25-2003, 08:31 PM
jx94148's Avatar
4 low is for running the motor in its happy powerband at very low speeds. I use it thru 3rd gear, if I need higher speeds in 4wd I shift from 3rd low to 2nd high in one swift motion while moving. That's about the same as 1st high to 2nd gear high. However its not possible on the newer 4WD systems. On the new stuff you have to be completely stopped to get from low range to high range.
You may find people writing about crawler boxes, Marlin cases or dual / triple transfer cases. These offer low range and ultra low range. Its used for driving over terrain that is shaped like the St. Louis Arch or the Empire State Building while not bogging down the motor into RPMs that are too low to be in the motors power range.
Hope that helps.
Old 04-26-2003, 08:27 AM
amorphous's Avatar
thank you
THANKS for the replies guys!
I decied that I should run my '98 in 4low going to get Chinese food last night
WRONG aplication!!!!
part duex, no manual included in my 2nd hand 4runner!
resources?
thanks again (i fell a BIT smarter now!)
aaron
Old 04-26-2003, 08:47 AM
Robinhood150's Avatar
The manual says it's for maximum traction, but that's a little misleading. If it's for maximum traction, then logically, you should be using it in the rain, snow, etc, on the roads. But that's not the case. Really, you should only use it when off roading.
Check out the 4runner FAQ here at yotatech, that should explain why it's not good for getting chinese food.
Flying91
45
04-11-2024 04:39 PM
westonian18
05-01-2020 06:38 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
sabine
07-18-2015 03:59 PM
DrZero
07-13-2015 09:59 AM
Quick Reply: There's no such thing as a stupid question.....
