Is there OBD II scan/diagnostic software for laptops?
For my Audi I can use my laptop to plug directly into the OBD II port, with a usb to OBD II cable, to read/clear any trouble codes as well as turn on/off daytime running lights, windows up/down with remote, doors auto lock above 15mph...etc. The software is specific to Volkswagen/Audi/Seat/Skoda.
I'd rather not buy another scan tool if I don't have to. Anyone using or know of a software app to use by laptop? Also, what about a flash programmer? Any flash programmers available or strictly send in the ECU to a company like JET and they desolder.
There are plenty of companies that make diagnostic software for OBD compliant vehicles. If the cable you already have is for OBD2 then it should work with any OBD2 vehicle. In fact Im not sure why the software wouldnt as well. I am currently looking into some products from Palmer Performance.
http://www.palmerperformance.com/products/index.php
Im not so sure about turning on off DRL, etc with it though. Thats something I never considered doing. You could also look into getting yourself a good OBD scan tool. Most of the nicer units come with software for your PC. A scantool will work on any OBD2 and sometimes OBD1 (for the nicer units) vehicle. Id say they are worth investing in. I have a scan tool built into my truck so I dont need it, but I have considered getting one anyway. They have a few more functions than mine does, and Im always getting frieds asking me to help with car troubles.
If you find something software wise, post up and let us know. Id be interested to see what else is out there.
Yeah, I had Googled it and found a few of them...just curious if anyone here had first hand experience with any or if any were more Toyota specific and not generic. I'm not interested in turning off DRL's I was just using that as an example that the Audi software is very robust in giving the user options. From the factory you can't roll down your windows with your key remote but with the software you can enable options otherwise not available. Also, I don't have DRL's in the Audi but with the software I just enable it so the fog lights act like DRL's. The headlights are auto sensing so they turn on at dark...well it just tells the same sensor to turn on the fog's during the day.
I think with my existing Audi software I can at least still pull codes for check engine lights, but you kind of have to know the software to find the right info...not really meant to interface with non Volks/Audi/Skoda/Seat vehicles.
For my Ford Exploder I had a handheld scan tool / flash loader. It worked as a scan tool and I could load different performance programs to the ECU such as "Torque 91" for towing/91 octane, "Performance 91", "Performance 87" and "Return To Factory"...didn't know if anything like that existed for Toyota as well. You could just flash the ECU instead of having to send it in and de-solder the EPROM and then some company (JET) reprogram it and re-solder it back into the ECU...the flash loader is much nicer and more convenient.
My understading is that VAG can pull regular OBD II codes, but you need to have the serial interface for it to work (I have the USB, hence, no workie).
I haven't seen anything specific to Yotas for software, so I haven't pulled the trigger yet either.
Just a few options that I was looking at:
http://www.scantool.net/
http://www.myscantool.com/
-batsoff
00 4Runner Highlander Edition
I use the BR-3: http://www.obddiagnostics.com/
The interface is a little archaic, but it was cheap ($100) and it does everything I need it to. I use a Serial-to-USB converter to plug it into my laptop. URD used to sell it, but it looks like they don't any more.
Here is the one that I was looking at getting. They have a few brand specific programs now. http://www.auterraweb.com/
does the BR3 show MAF info.....like what percentage the MAF is at during different rpms....i need a program that will monitor that im having problems with my supercharger over 4k and i would like this software to monitor it but i would like to make sure i can see the MAF info before buying it.
Blamalam
03-12-2022 07:34 AM
LittleUgly
15
01-02-2020 01:30 PM
nframe
3.4 Swaps
08-16-2015 09:03 AM
rjtrials
08-06-2015 07:25 PM
