Testing a U-joint?
Testing a U-joint?
There is a squeak in my girlfreinds 4Runner. It only does it occasionaly and usualy only at speeds around 15-30mph. It sounds like its coming from the rear of the truck. Its worse when youre on the gas or slowing down. Just like a U-joint. Well I took the rear driveshaft off a couple weeks ago and checked out the U-joints and from what I can tell they seem fine. You cant hear this noise when you just jack up the rear tires and spin them.
So how can you really check a U-joint?
How else can you find a squeak that you cant hear at slow speeds?
Sorry so long thanks in advance
The joint can be dry and squeak but still not exhibit any wear (yet). To check for wear, chock front wheel, leave in gear, jack up one side of axle just enough for tire to elevate (assuming you don't have aftermarket locker), spin elevated tire back and forth and observe joint for any play.
I checked it out again the other day. Its not exactly a squeak like I said before. Its almost like a tick. But it definatly only happens when youre on the gas. Well I greased it up and it still made the noise. After a day though it stopped. Hopefuly it wont come back. If it does Ill have to look into it more. We shall see.
grease those babys every 2500 miles or EVERY oil change.
this is the most commonly overlooked maintenance procedure on toyotas..
if u are in the mud or off road..do it more often..
like pappy always said, "son, grease is cheap. parts aint."
accuracy
09-20-2015 07:44 PM
