temperature gauge in 02 tacoma v6 maxing out
Old 06-28-2010, 06:11 AM
nexgen91's Avatar
Ok so I have a 02 supercharged v6 tacoma, the temp gauge goes all the way up while driving, at first it was intermitent but now its most all the time. I changed the ECT sensor with no effect, I read somewhere there is a seoerate sensor for the gauge, but I have no idea where it is. What should my next step be, and if it involves said sensor please can someone tell me where it is, maybe a pic? Thanks
BTW: I know its not overheating, because if I tap on the gauge it will read normal temp (I know its probly not good to tap on the gauge)
Old 06-28-2010, 06:59 AM
tunnelmotor99's Avatar
If you can tap on the gauge and it goes to normal, it sounds like the gauge itself is bad.
Old 06-28-2010, 10:17 AM
brian2sun's Avatar
I agree, if you tap on the guage and it starts working then it's not the sensor. When a gauge is pegged, it means it's grounding out so check the (-) wire to the guage. If securing the ground doesn't help, replace the guage.
calderp
Engine Swaps
08-16-2016 05:15 PM
Ernie217
08-14-2015 05:25 AM
calderp
07-27-2015 09:58 AM
edikp
03-13-2006 08:36 PM
Quick Reply: temperature gauge in 02 tacoma v6 maxing out
