Temp guage issues
Originally Posted by evilcow
When I start my truck the temp guage instantly redlines and stays there. Even when its cold. Whats up with that?
Does it return to normal after a few seconds of engine running?
Mine shoots to nearly red after its been driven for a lenghty period of time and restarted. However, after the engine has been running for seconds, it returns to normal.
Sender, gauge or wiring is shot. Factory Service manual should list the resistance tests for the sender and gauge, if they check out then it is the wiring. A quick test is to disconnect the sender and see what the gauge reads, then short the sender wire to ground and see what the gauge reads. I think normal operation is that disconnected=cold, shorted=hot.
its a 22re, hmmmm.... temp overshoot problem needing the upgraded 2 stage thermostat? check out 4crawlers site for info on it... it says for 87, but in reality, its all the 22r and re engines... my truck did the same thing, put in the 2 stage thermostat, been all better since
the1998sr5
15
07-14-2020 08:35 PM
nframe
3.4 Swaps
08-16-2015 09:03 AM
Poncho0206
07-10-2015 06:21 PM
