Teeter-Totter
Teeter-Totter
Simple question?? Maybe....maybe not.
I have a 1997 4Runner......completely stock, all original factory suspension. It has about 116K miles on it now, and the suspension and steering are getting loose. If I tap on the brake pedal at about 40 Mph, the thing rocks back and forth like a Teeter-Totter. I'm sure that I need new shocks on it, but my question is this........
What other components of the suspension should I look at? I'm just looking to improve the ride, not doing any off-roading upgrades. This one is my wife's soccer-mom grocery getter car, and we use it for any real winter driving up into the northwoods of WI where it plows through huge amounts of snow with the greatest of ease. I need the suspension solid to get the best possible snow/ice traction in that situation.
Thanks
Thanks
I would recommend going with the stock suspesnion setup from a 99 4runner. That year 4runner had slightly firmer suspension and raised half to an inch over other years.
Seems perfect for you: a slightly more aggressive suspension then what you have now, which will you feel more planted on the road with, but not over-the-top at all. For more info and a great guy to buy from go here: www.sonoransteel.com .
You can also upgrade some of your bushings to poly-urathane, that'll clean up some of the teetering too. Also on www.sonoransteel.com
Good luck, keep us updated.
sway bar?
I've seen some posts about the benefits of upgrading the fron/rear sway bars.......does anyone know if there's a good write-up on how to do that???
thanks
thanks
Sway bars are more side to side and the stock ones do a fairly good job. From what I read you are nose diving when braking? The 99 suspension will correct that, plus you'll get a little better cornering too. I'd also try upgrading the sway bar bushings to poly urethane before replacing the bars.
