Technical Question - Noise When Backing Up - Is It Normal?
Old 07-17-2003, 08:51 AM
Matt's Avatar
I've got a stock 2002 4runner (SR5 4 X 4) and have been noticing a noise when I step on the brakes while I'm backing up. This happens just prior to going from reverse to drive. Is this normal? Is there something adjusting that I'm not aware of? Please let me know if anyone else is experiencing this same noise. Thanks!
Old 07-17-2003, 09:11 AM
RidgeRunner's Avatar
I notice a metalic clank from the back of my truck when I apply the brakes when backing up. Seems like it just showed up recently, maybe since I just lifted it...dunno.
I looked back there but nothing looks obviously wrong.
Mick
Old 07-17-2003, 09:13 AM
rimpainter.com's Avatar
It might help if you described the noise...
Old 07-17-2003, 10:07 AM
It's hard to describe, but it's a clinking noise with a little bit of sliding noise right after, that may be close. And it happens when I first touch the brake pedal going backwards but not if I use the e brake. I at first thought a rear brake shoe noise but that should happen with the e brake too. Maybe the rear adjuster?
I'm going to have someone try to listen with better hearing than mine and see if we can come up with something better. I was thinking maybe slipjoint but that should occur when using the e brake too.
Thanks for the help.
Mick
Old 07-17-2003, 11:16 AM
Not yours, Matt's!
Old 07-17-2003, 11:19 AM
Fink's Avatar
LMAO
Old 07-17-2003, 11:57 AM
RTdawgs's Avatar
i get the same noise after about 10 ft of backing up, dont need to be pushing the brakes.
seems to be common, theres an earlier thread about it also.
Old 07-17-2003, 12:12 PM
Jay
Jay's Avatar
Hey Mick!
Does the noise only happen the one time when backing up, and requires you to drive forward and apply the brake before it will happen backing up again?
(this is a typical concern for other toyota's but I havent seen it on a 4 runner yet.)
Hows the lift? Galen said it was installed.
Old 07-17-2003, 12:23 PM
Right, Jay. It only happens once the first time I push on the brake pedal. One time when I was checking it this morning, it made the noise going forward too after backing up. It's like something loose is dropping against another piece of metal.
The lift is great! Where were you?? lol, we could have made it another community event.
Much thanks to Galen. (He's had a lot of practice.)
Mick
Old 07-17-2003, 12:40 PM
Jay
Jay's Avatar
Mick, that sure sounds alot like the front brake pad shifting in their holder. When you step on the brake going one direction, the pads shift one way, and stay there. When you go in the opposite direction, and apply the brakes, the pads now shift that way. I just cant recall there being much room for this to occur on the 4 runner. But I thought Id at least mention it. It sure sounds like this is what is happening. But perhaps its not.
Old 07-17-2003, 12:46 PM
Thanks, Jay, I'll check it out. Because of my hearing I can't really tell where it's coming from.
Mick
Old 07-17-2003, 12:52 PM
Jay
Jay's Avatar
Well, if your ever in Beaverton, stop on in and Ill have a quick listen for you.
bigjstang
08-25-2021 12:41 AM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
God's Bounty Hunter
07-08-2015 12:54 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: Technical Question - Noise When Backing Up - Is It Normal?
