taking rear door panels off
Old 03-29-2010, 07:28 AM
sl0annuggets's Avatar
I have searched and searched and I cant find a step by step of taking the panels off those rear doors. a link would be fantastic!!
Old 03-29-2010, 09:24 AM
blcktpgsr's Avatar
Should be easy..follow these steps:
Pry this up, it's held by two metal clips on each end..
remove 3 phillips screws..
slide door release to your right and pull out temporarily as its connected to a metal hanger..
remove 2 plastic clips on either side of the door..
insert a flat screw driver and pry off one section of the door panel. once you have enough room for your fingers to slide under, pull it from several places .see the locations of the mounting clips..there are 7 inside the lower part of the door. once all the clips are removed and the panel loose,pull it upwards and slightly turn to clear the door release. don't forget to pull the power window switch plug from the socket...
good luck!
Old 03-29-2010, 09:27 AM
hilux1026's Avatar
http://www.ncttora.com/fsm/index.html
factory service manuals
Old 03-30-2010, 06:38 AM
Awesome thank you!
Old 03-30-2010, 09:11 AM
blcktpgsr's Avatar
you are welcome
Old 03-30-2010, 09:31 AM
Elton's Avatar
gotta love pics its that easy
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
icentropy
07-11-2015 07:21 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: taking rear door panels off
