tails light problems!!
Hi guys!
I have a problem with my tailights. When the headlights are on, the left green arrow inside the cab stays on, regardless if I have activated the left blinker or not. in others words it always stays on. If you look the front, just a solid yellow light, the back is solid yellow. Now when i turn the headlights off and turn on the left blinker, the green arrow inside the cab blinks normally, but the tails light are messed up. both running lights blink along with the left yellow. I'm so confused. any ideas?
it kinda sounds like a combination of a blown turn signal bulb and wiring problem for the trailer harness. it sounds like they tried to use a standard type plug, for the type of vehicle that uses the same bulb for brake lights and turn signal. good luck--hope i helped some
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
Johntom240
7
07-13-2015 12:18 AM
madxman21
07-09-2015 10:26 AM
