Tacoma: What size ball drop for towing?
I'm going to actually use my hitch for something other than recovery in a few weeks. I need to purchase a ball drop and ball. What sort of drop is everyone using as the Tacoma rear end is so high? Is a 4 in. drop enough? Also, does anybody have any experience with the ball drops that have poly bushings inside to absorb shock?
Thanks
Thanks
Thanks
Thanks
I had a 4 inch drop on my 94 Ranger with a 3 inch lift on it. I was towing a small PVC trailer.
I use the 1" drop bar that came with the OEM tow package. At first I
though it would be too high but the boat puts so much weight on the rear
end that my truck rides level with the boat attached.
If I attached a trailer without so much weight, I would likely need about
a 4" drop.
a 4" drop.
I had this question a month or two ago and couldn't find a straight answer. I wanted to get a hitch to carry around in my toolbox for those very rare instances when I need to tow something. I don't tow boats or anything, just the occasional odd utility trailor.
I checked U-Haul's website and it seemed that most of their trailers were good with balls up to 25" high (you might want to check that figure).
Also, for a while I kept a tape measure in my truck and secretly measured a lot of other people's hitch heights as I was cruising thru parking lots and what not. I'm pretty sure the vast majority had their balls at around 17".
I have 3.5" of lift in the rear of my Tacoma and got a 4" drop. That put me right at 17".
09-04-2015 09:27 AM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
pyramid
07-29-2015 06:53 AM
coffey50
07-28-2015 10:55 AM
