tacoma transfer case options
i understand nobody makes anything to change the low gear in the tacoma transfer case.
what im wondering is if anyone can post some pictures of the internals of the case because im wondering why a different gearset cant be added.
does anyone know of an alternative bolton case that would allow the use of higher gearing?
thanks
thanks
Marlin would be the best source for crawler gears.
http://www.marlincrawler.com/htm/tra...e/taco_box.htm
right, im just looking for the most cost effective option.
plus i dont want to have to mess with driveshaft lengths or moving things around.
basically i really just want to get some pics out of this thread.
thanks.
thanks.
I don't have any pics of the internals, but I did install 4.7 marlins in my Taco last year and It wasn't that difficult for me. My truck crawls its ass off now. I couldn't see adding a doubler anytime soon, atleast not until I go SAS. There is just no need IMO. Remember, lower gears =more torque at lower RPM's which=axle breakage etc., at least if you wheel aggressively like I do.
The 4.7's make it considerably easy to go through harder trails with relative ease and more control than a stock gearset. My rig has the 2.7 litre plant and the lower gears make up for that lack of ooomph that I had with the larger tires, especially at higher altitudes. Get em' trust me you won't regret it.Marlin is the BEST!
the reason why you can't change the gear ratio is very simple, the chain driven T-case uses a planetary drive system and nobody makes aftermarket parts for it, because it would be too expensive. The older gear driven T-case has a typical gearset. There are several ways to have different gear ratios with the newer T-case design. You can add a Marlin Crawlbox to give you a lower range and recently Inchworm came out with a drivers side drop gear driven T-case that will fit that uses the same gearset as the older design, but with a cost, you lose shift on the fly.....
Can you explain how you installed those gears in a 2000 Taco T-case?
I'm talking about the gear driven transfer cases, they are totally different than the newer planetary drive systems.
With the newer T-case design, you can easily shift from 4Lo to 4hi, then into 2hi while moving, the older design you need to come to a stop to go from 4lo to 4 hi, otherwise you grind gears. In any case you can shift from 2hi to 4hi with any of the T-cases, but it's not recommended for the earlier types, especially if you forgot to lock the hubs....
That's why I'd like to know how you can put a 4.7 gearset into a Taco chain driven T-case, they don't fit. If you don't understand why, click the link in this post.
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
12-27-2016 01:58 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
yourrealdad
07-29-2015 11:08 AM
crashburnoveride
07-10-2015 06:39 AM
