| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Tacoma A/C just average on cooling ability?
__________________
My Ride: 2001 Xtracab Prerunner 73K miles 3.4L 4spd Auto Hella FF50 Driving Lights Dynomax Race Magnum Exhaust Crimestopper Alarm Clear Corners TRex Billet Grille Carbon Fiber Altezza Tails SmittyBuilt Nerf Bars Premier DEH-P460MP Cd/Mp3 Player |
#2 (permalink) |
Should be cold. Most probably a small leak in the system. Time to take it in for new seal/seals and a recharge.
#3 (permalink) |
It is quite possible the a/c system has a problem, unfortunately there really isn't a way to tell until you look at charge level, high and low side pressures, how much air you have in your system, etc. Remember though that heat exchanging is being conducted here and where it occurs is at the condensor. If you are sitting in traffic, don't expect much efficiency until you start moving and get that ram air flowing across the condensor coils.
As a rule, it's a good idea to run your a/c like every two weeks, some say everyweek. Even during winter times, by doing so, you help lubricate seals that otherwise would bust from drying up because no lube has circulated to them. A/C systems take a substantial amount of pressure (high ranges from 180-240 psi) so imagine if a seal is ill lubricated and you go to turn on the a/c system and the presure builds up to that amount. That's how a good amount of leaks develop.
__________________
2002 Imperial Jade Mica Tundra 2005 Acura TSX 6MT Navi 2006 Suzuki GSX-R600 Pic's of my Tundra Last edited by Mohamed; 07-14-2004 at 03:35 PM. |
#4 (permalink) |
Thanks for the tips, I might take it into the toyo dealer and get one of their $40 a/c checkups. Its under the 100000 mile warranty so anything over $50 is on their dime anyways if somethings broken.
__________________
#5 (permalink) |
best advice i ever got:
run your ac system once a week for a couple minutes to get the system lubed up... even when it's 0 degrees outside...
__________________
leo d. stock 90 4runner |
#6 (permalink) |
i'm not impressed by my AC at all
__________________
2003 Tacoma DoubleCab Limited TRD TRD Supercharger URD Fuel Kit K&N FIPK Flex-a-Lite Electric Fan Hayden Transmission Cooler Magnaflow Exhaust Test Pipe Hellwig Rear Swaybar (and its still slow!) |
#7 (permalink) | |
Quote:
#8 (permalink) |
in my 90 4runner's sales brochure, they have a picture of a cup in front cup holder and the caption, "use the a/c to keep your drinks chilled..."
or something to that effect... lol..............
__________________
#9 (permalink) |
My 98 stunk too. My buddy is a mechanic and cranked up the pressure with more R-134. Probably not the right thing to do but It's awesome now. He's a Ford mechanic so he's used to working on A/C systems!!
__________________
1998 Tacoma SR5 4x4 Extended Cab K&N Filter, Deckplate mod......that's it until I get a raise! Just added...Bilstein shocks and TRD Springs....Still waiting for a raise! |
#10 (permalink) |
Mine sucks too! It got to over 100 degrees today here in SoCal (yeah, lucky it's a dry heat
) and had the AC on high for about 10 minutes and it only stayed cool. Methinks it's time for a recharge; haven't had any maintenance done to the AC since I bought in in 9/98.
__________________
'99 Taco PreRunner V6 3.4L
#11 (permalink) |
I have a 99 with 49K on it. I notice a huge difference in the A/C from city driving to freeway driving. In the city, it is OK. On the freeway it gets COLD after about 10 minutes.
#12 (permalink) |
try turning the recirculated air button on... thats what i do, and it makes it SO much colder.
#13 (permalink) |
My AC is frigid. And guess where I live?
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#14 (permalink) | |
Quote:
Ditto. Sad to say but our Fords at work come out ICE cold! *brrrr* I don't like using my recirc button - I find that the mildewy smell is more likely to occur when I use A/C with that. Even if I shut it off and try to let the condensation dry out a few miles before I get where I'm going. |
#15 (permalink) | ||
My next door neighbor has a Tacoma double cab and he said the same thing- A/C is not that great. They have a Ford Focus and it is much better in that department.
I notice my A/C is colder when I accelerate than when I am sitting at idle... I think it all has to do with the ozone friendly refridgerants?
__________________
Owned YT-style Quote:
#16 (permalink) | ||
Quote:
Quote:
GM, some Chrysler-Dalmer, and some Fords instead use an OT or orifice tube to cause restriction, in that case an accumulator is used instead of a reciever-dryer...both designed to remove air and moisture through means of a dessicant, the accumulator has the advantage of it's name and that is to accumulate excess refrigerant, flooding the evaporator is not efficient, nor good for the compressor either.
__________________
2002 Imperial Jade Mica Tundra 2005 Acura TSX 6MT Navi 2006 Suzuki GSX-R600 Pic's of my Tundra |
#17 (permalink) | ||
Um ok Mohamed, did you hear that? It's the sound of no one giving a damn! j/k (stole that one from the insult dog on conan)
__________________
#18 (permalink) | |
Quote:
__________________
2000 UZJ100 Land Cruiser 2" OME and 33" Geolander AT's Blue Ribbon Coalition Toyota Land Cruiser Association |
#19 (permalink) | |
Quote:
__________________
#20 (permalink) |
I have no complaints about the A/C on my '98 Taco, but then again maybe that's just because I went for about 9 years without any A/C at all.... :-P
#21 (permalink) |
Guy at the a/c shop told me a while back that if the fan clutch isnt working properly it can affect the a/c system. The fan clutch on Toys are serviceable. You can take them apart and add 2 tubes of the silicone gel availible at the dealer parts counter. I did this on my old 22re truck and it wasnt a hard job. Cost about $20.
__________________
'96 Tacoma 4x4 SR5 Xcab 3.4 5spd ARB Rear Locker Bilstein Shocks Center Line Wheels w/ Cepek FC2's Deckplate & ISR Mods K&N Filter JBA SS Cat-Back System B&M Short Throw Shifter(I like it) Alpine Sound System w/ XM Radio |
#22 (permalink) |
Mine works well on recirculated air. Not so well on outside air. Its the same with my girlfriends Heep.
__________________
2000 Taco SR5 V6 5speed TRD Airaid MIT Vortex muffler DEI 2-way Extang Tuff Tonno III |
#23 (permalink) |
I wish my truck had the little side windows that open out and "scoop" the air in. I'd rather have those in there and all the windows open while cruising down the highway rather than have the A/C on. Seems that only the Ford trucks at my job have them.
__________________
'02 4Runner - '06 XRunner Breakdancing www.BadgeYourRide.com Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/ Highest Xmax 6.5" subwoofer made Total Posts: 32,218 (75.35 posts per day) [/center] [/color] Still A Neon |
#24 (permalink) | |
Quote:
I used those alot because my a/c didn't work on my Runner, thanks to good old papa when he gave me the Runner, he never used the a/c alot because he thought it "saved gas" In the process, the seals ran dry and busted on me, when I went to go use it.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear Seat Fold-ability Help? | SwampThing | 86-95 Trucks & 4Runners | 7 | 01-28-2007 02:39 PM |
| Towing ability of 4 cylinder engine? | vmax84 | 86-95 Trucks & 4Runners | 6 | 07-23-2005 11:24 AM |
| not your average flash game 2 | CLin9383 | Off Topic Talk | 19 | 02-25-2004 06:32 PM |
| Not your average flash game | Robinhood150 | Off Topic Talk | 75 | 02-25-2004 02:01 AM |
