Tacoma beadlocks/street locks...searched and can't find anywhere!
Old 06-08-2009, 09:15 PM
Justin89's Avatar
Question Tacoma beadlocks/street locks...searched and can't find anywhere!
Hey guys, I have a 95.5 Tacoma and want to find some street lock bead lock rims/wheels. I have searched every where for them and can't find the specific size I need or Tacoma specific. I even tried the "Les Schwab" Allied Street lock wheels but they rub on the front caliper. Any one have some ideas of where I could go. I dont mind going up in size either. Any help would be GREATLT appreciated!
Old 06-09-2009, 05:00 PM
SnowRunner98's Avatar
i'm assuming you want to run your 32's. just get any wheel you like with the 6 on 5.5 bolt pattern. http://www.roughcountry.com/black_wheels.html
http://www.roughcountry.com/mickey_t...ssic-lock.html
nor sure what style you like.
not sure why they would rub your caliper unless you did the tundra brake upgrade, unless you have 4runner calipers on there. but then your 15's wouldn't fit?
Old 06-09-2009, 08:21 PM
Justin89's Avatar
I want the first set. I dunno why they rub either but the ones like ^ (first style) and the bead locks (both made by Allied) rub only on the front. So has anyone ran the ones above on a TACOMA? Great price for the rims...
Old 06-09-2009, 09:05 PM
ETRNL's Avatar
just buy you a set of Stauns and be done with it...
http://www.staunproducts.com/
http://www.staunproducts.com/beadlock.php
Old 06-10-2009, 08:55 AM
SO you have 15's on right now in your avatar?
Old 06-10-2009, 08:40 PM
Justin89's Avatar
Yes I do
Old 06-11-2009, 06:39 AM
i'm confused why those fit and the others don't? just go to a tire shop, try on a common 15x8 baja and note the backspacing.. which should be a common backspacing. then order your wheels from somewhere cheaper.
Old 06-15-2009, 06:34 AM
toytim's Avatar
High Impact beadlocks
I gots me some high impact beadlocks.. you can fit 15" rims if you have the correct backspacing.. http://www.high-impact.net/wheels/index.htm
94whiterunner
07-12-2015 07:15 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
TokyoD23
07-12-2015 06:01 AM
Poncho0206
07-10-2015 06:21 PM
akaphilly
07-09-2015 02:18 PM
Quick Reply: Tacoma beadlocks/street locks...searched and can't find anywhere!
