Tacoma 2.4/2.7 valve adjustment?
Old 11-30-2003, 08:39 PM
VolcomTacoma's Avatar
Well on my other truck a 98 Tacoma with the 2.4 (but assume it's the same valvetrain as the 2.7?). There is a faily noticable ticking/rattling sound after it's warmed up and at idle. At start-up or when its cold and at idle it's not loud. My 2.4 has about 100k miles and runs fine. So if this is normal I don't really care about the sound, but do you think I need a valve adjustment? Anyone else's Tacoma 2.4/2.7 sound like this?
Old 05-19-2004, 04:43 PM
barzini's Avatar
Yes, my 97 Tacoma 2.4 taps and it also has a rapping sound on acceleration coming from the valve cover. The truck has 120,000 and runs good,Did you adjust your valves? If so was it tough? Any help is appreciated.
Thanks, Barzini
barzini's Avatar
Thanks, Barzini
Old 05-19-2004, 07:46 PM
Thanks, Barzini
I don't have the truck anymore and did not adjust the valves. It is not too complicated of a process, but you start off by checking the valve clearances and seeing if they are within spec or not. I have not done this before, but watched someone do it. The factory clearances should be on a sticker under the hood. There is probably a complete writeup on adjusting your valves online.
smthwsn357
12-04-2023 02:08 AM
94whiterunner
07-12-2015 07:15 PM
razorman8669
07-12-2015 12:13 PM
Poncho0206
07-10-2015 06:21 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Tacoma 2.4/2.7 valve adjustment?
