YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-12-2004, 10:05 AM   #1 (permalink)
Nolan's Avatar
synthetic tranny fluid at 120k a good idea?
I have a 1996 4Runner with 120k on it. I am going to be changing the tranny fluid and I want to use the Redline MT-90 which is synthetic. Should I have any concern about using synthetic on my high mileage truck? I have mainly heard in regards to engine oil that the synthetic oil has a tendancy to find weak spots in seals due to its finner properties. Does that also go for tranny fluid? Currently I have no leaks on my truck.
__________________
* 4runner * 2WD 2.7L 5spd * 4.88 Precision Gears * Rear ARB Locker * ARB Compressor * 2.5" front/2" rear CF spacers * 4wd springs * Bilstein shocks * 285/75/16 BFG AT's * 16x8 Ivan Stewart TRD wheels *Gibson exhaust * Yakima roof rack * Rocky Mounts Bike Rack * Yakima Lift Ticket 6 Snowboard Rack * Amsoil Air filter * deckplate mod * Optima 34R Red Top * 15% front Tint * PreRunner Front mud flaps * PIAA 1400 fog lights * '02 4Runner Sport Skidplate & Tube Steps * Husky Floor Liners *
Nolan is offline
Sponsored Links
To remove this ad, register today!
Old 12-12-2004, 10:26 AM   #2 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
its fine.... my truck probably has around 200k+ miles, and when i can afford it, im going to be using GM synchromesh in the tranny
jimbo74 is offline
Old 12-12-2004, 05:26 PM   #3 (permalink)
good .
Use it, just check the fluid level in a few weeks. You shouldn't regret it.
84runner is offline
Old 12-12-2004, 10:05 PM   #4 (permalink)
turboale's Avatar
Send a message via AIM to turboale
Yeah, I use BG full synth in my tranny. Thing works like a dream (and I'm hard on my poor truck).
__________________
--Austin
06 M45 Sport - Beauty
96 4Runner - The Beast
turboale is offline
Old 12-13-2004, 07:27 AM   #5 (permalink)
4Runner4Christ's Avatar
If your engine has been properly maintained and has no signs of leaks you can start using synthetics. I would suggest Amsoil XL7500 after doing the Amsoil engine flush thing.
__________________
Black 99 4Runner 4WD . Mods: 1" Cornfed lift with LT265-75 AT's, Deckplate mod, Rear Diff Breather mod, 100% Amsoil, FIAMM horn mod, Husky's, '01 taillight mod, & others. 135K Miles, new TimingBelt-H20 Pump-SpPlugs. <><
Got Eternity?
4Runner4Christ is offline
Old 12-13-2004, 07:31 AM   #6 (permalink)
Nolan's Avatar
Are you refering to engine oil or tranny fluid? I think as far as engine oil goes I am not balsy enough to switch just because dino has been working and I think I will stick with it. But as far as the transmission and differential, I would like to get those on synthetics.
Quote:
__________________
Nolan is offline
Old 12-13-2004, 07:39 AM   #7 (permalink)
FilthyRich's Avatar
if your truck has a bunch of miles, synthetic engine oil can only benefit you. IMO. I run Amsoil synthetic everything and I have 97k miles.
__________________
Eric
88 4runner
Quote:
Originally Posted by AxleIke
"Just wheel what you got until it doesn't cut it anymore".
FilthyRich is offline
Old 12-13-2004, 07:41 AM   #8 (permalink)
FilthyRich's Avatar
Quote:
...you said 120k...my bad
__________________
Eric
88 4runner
Old 12-13-2004, 04:25 PM   #9 (permalink)
Nic
Nic's Avatar
Nolan, I swithced over to Amsoil for my transmission and diffs/t-case when I bought my truck. Still using dino for the engine. It had 110,000 miles on it when I bought it. I have not had any problems.
I did, however, drain the Amsoil from the transmission and switch over to the Redline MT-90 since my shifting was not that great with the Amsoil. I have been pretty happy with the Redline in the transmission and I guess the Amsoil is doing OK in the diffs and transfer case.
__________________
Nic
1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed
Nic is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Good idea? Bad idea? Cheap Blower intake. YotaTruck1986 95.5-2004 Tacomas & 96-2002 4Runners 29 01-16-2008 08:24 PM
Synthetic diff. fluid DirtyDeeds/DirtCheap 95.5-2004 Tacomas & 96-2002 4Runners 7 05-13-2007 10:55 AM
$390 for 3rd gen 120k service -good deal? 4Runna 95.5-2004 Tacomas & 96-2002 4Runners 6 05-04-2006 07:16 AM
?? changing tranny fluid + trans case fluid + diff fluid.... sage 95.5-2004 Tacomas & 96-2002 4Runners 1 06-22-2003 09:38 PM
Synthetic fluid question obxfishn 95.5-2004 Tacomas & 96-2002 4Runners 8 05-27-2003 02:53 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
