YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 05-21-2007, 07:06 PM   #1 (permalink)
Personal Sales Rating: (0)
Mojo_Risin's Avatar
Send a message via AIM to Mojo_Risin
Is this a symptom of a starter or solenoid going bad?
For about the last month I've had an intermittent starting problem. Sometimes I turn the key and the get just a crank or two and it just stops cranking. Try again and it starts right up nice and quick. Or sometimes I get no cranking at all. Try again - get maybe 2 cranks and it stops. But (knock on wood) always ends up starting. I never get the tell-tell clicking noise of a bad started. I replaced the battery to an optima - cleaned the cables, battery connection is tight. One other weird thing is it seems to happen more on HOT days - not when the truck is hot per se but just hot outside.
any insight?
John
__________________
'97 4Runner SR5
Front: Tundra Coils/Bilstein 5125's | Rear: LC Shocks & Coils + SS rear "fixes" | Custom Sliders
285/75 TreadWright Guard Dog MT's | Retrofit E-Locker | TJM T15 | Custom Rear Bumper | Warn m8000
Mojo_Risin is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 05-22-2007, 01:37 AM   #2 (permalink)
I know on my ranger I can turn the key to the ON position but don't start it. Then jump the solenoid to crank the starter. That way I can tell if the starter's bad. I don't know if its the same W/ a 4runner? Just an idea to try since both the starter and the solenoid are kind of expensive. Good luck. Let us know what you end up doing.
cox380 is offline
Old 05-22-2007, 04:39 AM   #3 (permalink)
GSGALLANT's Avatar
This is just a copy/paste of the answer I posted on your thread over at UltimateYota.
I'd still put money on starter contacts (or maybe the starter relay). There is an easy test you can do. It isn't really easy to get at, but it's do-able... remove the small control wire going to the starter (It's held on with a clip that locks in place when you push it in, so there's a small tab you have to push in before you pull it out. I used a really long screwdriver to push the tab in while I pulled on the clip with my free hand.)
Put the hot lead from a voltmeter to the wire you just remove, and ground the negative lead from the voltmeter somewhere on the frame or engine (clean rust to ensure you've got a good connection to ground). Have somebody turn and hold the ignition key to "Start" for approx 5 seconds, and verify that you're getting approx 11.5-12.5 volts on your meter. Repeat the test 5 or 6 times to make sure you're getting consistant results.
If you are getting good voltage at the control wire, order up some starter contacts and rebuild that starter. If you're not getting good voltage, start by checking the starter relay (there are a few other switches to check as well, but the relay would be my first guess if you don't have good voltage.)
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2007 FJ Cruiser - stock
GSGALLANT is offline
Old 05-22-2007, 06:04 AM   #4 (permalink)
this is a simple fix, there are many threads about it. At 4Crawlers website, he even sells the contacts inside the solenoid assy. search
BruceTS is offline
Old 05-22-2007, 10:58 AM   #5 (permalink)
GSGALLANT's Avatar
Quote:
Originally Posted by Ric View Post
Mine did the exact same thing last year, it was the starter. replaced the starter.
havent had any issues since.
To replace the starter, you have to remove it anyways, so you may as well save some money and just rebuild it. It's pretty much the same amount of time, 10 times less cost, and will double the life you get from your starter.
__________________
Old 05-22-2007, 11:50 AM   #6 (permalink)
Threadstarter [OP]
Mojo_Risin's Avatar
Quote:
So would I get 1 of his "A" contacts and 1 of his "B" contacts for the 3.4L engine? I like the rebuild idea - just not sure what contacts to get. Here's the page... http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
EDIT: I found it on his site: "Most of the Toyota V6 starters (3.0L, 3.4L) use an A-style motor side and a B-style battery side contact "
John
__________________
'97 4Runner SR5
Old 05-22-2007, 03:07 PM   #7 (permalink)
toyota_mdt_tech's Avatar
Worn starter contacts. Easy fix, get them at the dealer.
__________________
Toyota Master Diagnostic Technician
"MDT"
2010 Ram 2500 Cummins 6 spd
2003 Toyota Highlander 4WD
2006 Toyota Tercel 2DR
2007 KTM 105SX
2007 KTM 85SX 19/16
2006 KTM 300XC-W
2002 Yamaha TTR 125L
2002 Kawasaki KLR650
2002 Suzuki Eiger 400 4WD
Licensed "Amateur Extra" Class Ham Radio Operator
toyota_mdt_tech is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
2002, 2007, bad, clicking, eiger, relay, replace, solenoid, starter, suzuki, symptom, tacoma, toyota, tundra, v6, versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
starter solenoid mendozart 86-95 Trucks & 4Runners 17 11-24-2011 11:13 AM
Symptom of a bad starter? bryanr 95.5-2004 Tacomas & 96-2002 4Runners 2 12-05-2005 03:33 PM
Wet Solenoid?? Starter issues... msw0085 95.5-2004 Tacomas & 96-2002 4Runners 6 05-31-2005 07:59 PM
Starter solenoid Tacoma Dude 95.5-2004 Tacomas & 96-2002 4Runners 6 06-22-2003 12:50 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
