Sway Bar problem
Old 10-15-2007, 03:43 PM
hopper's Avatar
Sway Bar problem
Not to long ago I changed out my sway bar bushings trying to get rid of my thump in the front end driver side. Well its still there and every so often I check under to see if anything is new and.. today there was!
Driver side sway bar link bent and broken and passenger side bent and on way to broken. Here are some pictures.
Passenger side \/
Driver side \/
What could cause the links to bend and break like this? I did a little offroading to go shooting on the 13th but nothing that would make me think I would have done this.
Old 10-15-2007, 03:47 PM
ozziesironmanoffroad's Avatar
remove it! lol. umm... rusted thru maybe... but that break looks clean.. as in purposely cut...
Old 10-15-2007, 03:49 PM
hopper's Avatar
No its a bend and break. I live in Las Vegas and I dont think its b/c of rust.
Old 10-15-2007, 03:51 PM
yeah your right about that.. upon closer inspection yeah i can tell its not rust. its got rust flakes, but yeah that shouldnt do anything, rust doesnt spread out here. did you do any jumping or anything with it?
Sponsor
Tofer's Avatar
pull it.... or build quick discos
Old 10-15-2007, 04:01 PM
urbanj's Avatar
did you have the truck in the air when you tightened everything down?
hopper's Avatar
Ya I didnt realize you were from here.(Vegas) No, no jumping! Some light 2wd trail. ..... Now thinking of it, it could have been from my Mojave Road trip?!? IDN!
I will probably buy some from WabFab.
Old 10-15-2007, 04:02 PM
hopper's Avatar
The front end yes.
Old 10-15-2007, 04:05 PM
hopper's Avatar
Is there a write up on DIY disco's? I dont have $150 right now to buy WabFab.
Old 10-15-2007, 04:10 PM
when you get those discos, we should do a trail ride to test them out
Old 10-15-2007, 04:14 PM
urbanj's Avatar
That could have done it. Any suspension part should be torqued when at ride height. When on jacks the suspension will be at full droop. Then when you tighten up the swap bar and drop the vehicle the bar will be preloaded. so now when you took it off road and flexed the suspension it was too much for the tiny flimsy endlinks.
They make adjustable sway bar endlinks so you can dial in the preload in racing applications. But those are for cars and not trucks with huge amounts of suspension travel.
Old 10-15-2007, 04:17 PM
hopper's Avatar
Never thought of that
That may be it!
Old 10-15-2007, 04:27 PM
User 051420's Avatar
When you replace it, would you be willing to send me the bottom nut of the end-link? I'll gladly pay for your time +shipping.
Old 10-15-2007, 04:29 PM
urbanj's Avatar
That get's me thinking. I'm pretty new to the 4x4 world but is the sway bar addressed in lifted applications. Because with a taller spring there will be preload. Using beveled washers to shim up the bar on the link and have zero preload might help the ride. And thats probably why guys break the links on the trail with lift. I'll have to go under and actually take a look around.
Old 10-15-2007, 04:30 PM
hopper's Avatar
If I dont reuse it, its yours! Are you talking about the one connecting the bottom link to the A arm?
Old 10-15-2007, 04:32 PM
Exactly. I lost mine somewhere!
PM me when you're ready.
Fantastic!
RatOmeter
10-22-2015 03:17 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
DrZero
18
07-24-2015 11:31 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Sway Bar problem
