Swapping in a tilt steering column
Old 02-03-2005, 10:13 AM
hub_01_69's Avatar
I have a 91 toyota pickup with a fixed column and may be able to get my hands on a tilt column from a 94 toyota pickup really cheap. My question is, has anyone done this or know if it will fit? If it does fit how hard of a job would it be? I searched and came up with nothing....
Old 02-03-2005, 11:57 AM
Flamedx4's Avatar
Pretty straighforward. Unplug it, unbolt it and bolt the new one in.
The thing that can get difficult is whether or not the new one has the same switches. If all the same, plug in the harness and you're good.
If the new one has an airbag wheel, you'll want to be really careful when you disconnect that and take off the wheel. Disconnect the battery first, then unplug the harness up under the dash before touching the wheel.
jasonty
41
12-23-2018 01:00 PM
kirkrunner
07-27-2015 07:59 PM
keithporter83
07-24-2015 07:37 AM
whereAreMyPants
07-22-2015 03:32 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: Swapping in a tilt steering column
