| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
swapped 882 for TRDs. Rear end Alignment ?
__________________
-1999 4Runner SR5 Highlander 4*4 Looking to get it locked! -1991 BMW 318is Alpine White 5spd -1982 Yamaha Maxim XJ650 58.6MPG according to TankBuch |
#2 (permalink) |
i didnt think there are any adjustments in the rear for alignments.
#3 (permalink) |
It looks like they have the machine set to Rav4 mode and not 4Runner mode - maybe that has something to do with the squirrelly feeling in the back suspension? Incorrect parameters for the camber, caster, etc. will definitely have a negative effect on handling. Make sure that the "specified ranges" are correct
__________________
2002 Limited 4wd Stuff OME 881/906|OME N91SC/N86C|ToyTec diff drop|TRD catback|TRD plug wires|285 Terra Grapplers color matched exterior|Andymod|Amber Hella 500's|LED tails|clear corners|black emblems|25% tint Audio TomTom|Infinity|Kicker 08ZX750.1/08CVR12|Jensen VM9412/iLink|Dynamat Last edited by 02_Limited; 11-09-2009 at 11:34 PM. |
#4 (permalink) |
the set vehicle doesnt mean jack if you know what your doing, all it does is tell you if your within factory specs for that vehicle. your camber looks great, caster is fairly decent, your toe is a little too negative for my tastes, i prefer .05 at least, i usually set to .10 degrees. the problem i see is your rear thrust angle is way off, looks like the left side is kicked back which would theoretically only cause the truck to cat walk sideways down the road.
__________________
They call me the "Short Bus" 89 pickup SR5 3VZ-E 5 speed 4X4 5" HD trail gear sas | rock sliders | u bolt flip kit | 6" shackles | 38X12.50 TSL's | led rock lights | 5.29's dual t-cases 2.28 and 4.70 | welded front and aussie locked rear | bud built flat belly skid marlin crawler rear bumper | trail-gear front bumper | x-plod amp & kicker cvr 12 Flowmaster | K&N system | 125" wheel base | cb http://www.youtube.com/watch?v=yQbF4ThlNEI |
#5 (permalink) | |
Quote:
I was thinking about it and when I first put my lift on a friend cut my panhard bar and welded a sleeve to it. Since then my suspension has settled 3/4 to 1 in. Could this cause problems with the thrust angle?
__________________
-1999 4Runner SR5 Highlander 4*4 Looking to get it locked! -1991 BMW 318is Alpine White 5spd -1982 Yamaha Maxim XJ650 58.6MPG according to TankBuch Last edited by E30RUNNER; 11-10-2009 at 07:33 AM. |
#6 (permalink) |
if you were getting your rav 4 lined then the rear is still in bad shape. take it back to ntb and have them do an alignment to your 4runner, unless you prefer the rav 4 specs.
#7 (permalink) |
It's going back today.
__________________
#8 (permalink) | |
You can push the rear housing around some with the u-bolts loose. We use a port-a-power with good results. The center pin within the spring pack is a little smaller than the hole in the spring perch so you can push the right side back, remeasure and then push the left side forward if needed.
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks 32x11.5-15 BFG AT's Quote:
#9 (permalink) |
lol 3rd gens dont got u bolts there all coils have you checked the axle to see if its centered might have to get a adjustable panhard bar
#10 (permalink) | ||
Quote:
In this case look at your links/trailing arms. One might be bent.
__________________
#12 (permalink) |
That shop should not have charged you extra to align the rear as there are no adjustments to be made. They usually won't tell you that and just get you for another $30. If they did, demand a refund! The only adjustment that can be made is to install an adjustable pan hard bar (like the others mentioned above).
I don't see how they got before and after measurements on the rear. That printout looks like BS to me.
__________________
97 4Runner SR5 3.4L 4x4 305/70R16 Mastercraft M/Ts on black stock 6 spokes 2.5" suspension lift ARB Bullbar ARB rear locker 4.88s Factory wood grain dash My 4th Toyota truck "If guns kill people, then pens write novels." |
#13 (permalink) |
And yeah, he's got you listed as a Rav4 with tiny little pizza cutter tires - not 33s.
__________________
#14 (permalink) | |
Agreed. Since the cargo is usually people now with soccer Mom's and all, it seems softer is better.
Those rear readings don't surpise me. The slight difference between before and after are so slight that the readings were probably right on the bubble. The machine may do some rounding off too. You definately shouldn't be charged for a 4 wheel alignment. A thrust angle alignment may be sold to ensure a straight steering wheel though. But a slightly off steering wheel doesn't wear tires and isn't actually out of alignment. Just cosmetic.
__________________
#15 (permalink) | |
Quote:
My total cost for the alignment was $50 bucks and some change.
__________________
#16 (permalink) |
measure the width on both sides and see what it is
#17 (permalink) |
Would you check it by seeing how much each wheel sticks out on either end?
__________________
#18 (permalink) |
with my tires from touching the the frame from where the swaybar end links are to the end of the tire lugs are is roughly 13.5'' thats how i checked mine
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods Mom 07 Tundra d-cab limited 5.7L 4x4 auto sister 92 pickup SR5 X-cab 3.0L 5spd 4x4 Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck Last edited by Elton; 11-10-2009 at 01:20 PM. |
#19 (permalink) |
Wow, Jesus worked on your truck. Blessed is your suspension.
__________________
My Build Thread The 4Cruiser: 98 4Runner SR5, 5VZ-FE, Sonoran Steel 1.2, BCC custom swing-arm rear armour, full Budbuilts, 285/75R16 Goodyear Duratracs, extended diff breather, airbox deckplate, red LED cluster, console,Wabfab front discos, Warn M8000 winch, Shrockworks full hoop, PIAA 520s and 510s, Stubbs HD-SKO Sliders, External tran cooler, tundra brakes and 5.29s and ARB lockers next |
#20 (permalink) |
I feel better already!
here's the second read out for today's alignment
__________________
#21 (permalink) |
the cross caster is still a little high. cross caster and cross camber should be close to 0. in my opinion the tech was being lazy. but at least he set the toe higher to a more reasonable degree.
i see they both came up with the same results for thrust angle. and like i said before thats just going to make your ass end kick out to the left a little and maybe clock the steering wheel off a little. and these guys are right you should only be charged for a 2 wheel alignment, however 50 bucks is a hell of a deal so i wouldnt complain.
__________________
#22 (permalink) |
most shops only do 4 wheel now. can't set the thrust line on a 2 wheel. yeah, he should have crossed the caster camber a little better, id be surprised if it doesnt pull a little.
#23 (permalink) | ||
Quote:
Quote:
Off subject I had a buddy drive it who didn't believe a truck like mine lifted could ride smooth drive it...he's a believer! It's suprising how well they ride if you plan and make the right adjustments for them. I'm really liking the OME shocks
__________________
#24 (permalink) | |
Yeah with that caster, she can pull right some but if not, don't worry about it.
__________________
| Tags |
| 4runner, 4x4, alignment, axle, bar, end, front, panhard, rear, specs, suv |
