Swaped 3.slow for 3.4L NICE! - Page 2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-06-2003, 09:15 PM   #26 (permalink)
i think your truck is baaaddddddddd!
i completely agree that the supply curve has made buying 3.4's almost a joke. but with people like you around showing the potential for a clean swap it should soon change. guess ill see about grabbing another 5vz while theyre still cheap
welcome to yotatech!!!!!!!!!!!!!!!!!!!!!!!!
__________________
jake
its2slo is offline
Old 09-07-2003, 05:29 AM   #27 (permalink)
Victor's Avatar
I know you said the 3.0 clutch will not work. What about those of us who want to reuse our HD 3.0 clutches? Shouldn't we be able to use our clutches as long as we use the 3.0 flywheel and starter? I know the stock 3.0 clutch may seem weak. Also - Marlin Crawler lists the same clutch for the 3.0 and 3.4 - it is based on the fact that both use the R150F tranny.
__________________
"Turtle" - Green 94 4Runner
Looks like one and about as fast
JDM altimeter/clinometer, 2002 Sport wheels, 265/75r16 MT/R, , OME stabilizer, BJ Spacers, Cruiser Coils, removed sway bars, rattle can paint for all that peeling clearcoat! Lockright front and rear.
Victor is offline
Old 09-07-2003, 02:10 PM   #28 (permalink)
Vato Loco's Avatar
Send a message via AIM to Vato Loco
You have any dyno results or any ET times?
__________________
2005 Toyota Tacoma Access-Cab 4x4 w/ TRD Off-Road Package
33" Goodyear MTR's
3" Toytec Lift
Clear Headlights
Quick Pic of the Taco
My Old Toyota 4Runner Limited, Check It Out!
Vato Loco is offline
Old 09-07-2003, 03:21 PM   #29 (permalink)
3.0 to 3.4 Swap
I have not dynoed or ran the 1/4 mile yet. As far as the 3.0 Flywheel fitting the 3.4. I don't see any reason why it would not fit. When I had both the 3.0 and 3.4 setting side by side. I took a very close looks at the crank shafts and they do look identical and both use 8 bolts to hold them on. I'm sure the reason it is not recommended is the friction surface on the 3.4 clutch disk is a lot larger and can hold up under a lot of power. Just to give you an idea of the amount of torque I am putting through a stock Toyota 3.4 Clutch. I towed a wrecked 1990 4x4 4Runner from Missoula Montana to Spokane Washington on Interstate 90. Anyone that has driven that stretch of I 90 knows about Lookout Pass. It is a VERY steep mountain pass for about 6 to 8 miles. I pulled that 4Runner rolling on its own 4 wheels up and over that pass in 5th gear averaging 80MPH. Yes, you read correctly. I was passing full size FORDS, CHEVYS and DODGES pulling boats, campers and what ever that were not even close to keeping the speed limit. The torque is the most impressive thing I must say. I have towed several other Toyota trucks with my Supercharged truck. All tow like I'm not towing anything. Passing on a two lane highway is not a problem with a Truck in tow. just drop to 3rd gear and your gone. Even with 3500 plus pounds of DEAD weight in tow. Some of you are probably wondering about fuel mileage. Well, its actually VERY good when not towing anything and driving relatively normal. On the highway not towing and averaging 70 miles per hour. I usually get about 26 MPG and that included a few sling shot passes of slow jackasses now and then. Now when I tow a truck. The mileage drops to around 17 to 18 MPG. I know what you are thinking. damn, that truck does the same mileage towing a heavy load as my truck empty with a TURD 3VZ engine. Bottom line, If you need to replace your engine or rebuild it. JUNK IT, go 5VZ!!! you will never regret it. DON'T WASTE YOUR TIME AND MONEY ON A DEAD HORSE ENGINE!!!!!!!!!!!! "3VZ" JUNK. For those of you looking for a donor truck or 4Runner for a good 5VZ. Keep in mind if you plan to Supercharge. Try to stay 1997 or newer. 1995 is NOT supercharger friendly 1996 will work ok, but 1997 is the first all around good responder to a Supercharger. Now if you do end up finding a 1995 or 1996. The 1997 ECU will fit the engine harness plugs on the older two years. 1998 is ALL ALONE. Will not swap up or down any years. 1999 and newer ECUs will interchange with the plugs styles on the 2000 and up harnesses or vice versa with the newer ECU to an older hanress. 1999 to 2002. In my truck, The engine & Harness came from a 1996 5 Speed 4Runner but the ECU I am using is from a 1997 5 Speed 4Runner. I insisted on using the newest ECU that the older engine harness would except. Good luck and hope this bit of info helps you out.
Take care,
Matt McCullough
__________________
g
MODMAN is offline
Old 09-07-2003, 05:15 PM   #30 (permalink)
RebuiltRunner's Avatar
Quote:
Originally posted by Cebby
If I'm not mistaken, that's Cannonball Run on the DVD...
Cannonball Run 2, is it not?
I love this little truck. Also note the appreciation of high-end car audio (eclipse dvd player)....swanky.
__________________
Peace: CW
2000 Taco PreRunner V6
Amsoil Air & oil (SDF34), XL7500 oil, big ol' Yoko Geolander HT-S (black side out) Eclipse 4222R/5122 changer, Rostra add-on cruise control. Eurolite Xenon superwhite in inst cluster. As of 2/21/04, BIG, FAT, GAPING 6-INCH DECKPLATE MOD!!! (+3,000 HP, 370 MPG)...anybody know where I can get REAL #74 xenon bulbs for my A/C controls? Imperial 11x11 Maxi-Cool(er)
RebuiltRunner is offline
Old 09-07-2003, 05:59 PM   #31 (permalink)
Yes, That is Cannon Ball Run.
Matt
__________________
g
MODMAN is offline
Old 09-08-2003, 01:02 AM   #32 (permalink)
The jaw has officially dropped...
I finally read your two big posts above.....wow. I don't even think a '96 to 2000 non-prerunner 4x2 v6 will get 26 mpg and def not with the SC. I'm fighting the urge to ask you, if I bring my '00 taco pre v6 up to Spokane, would you drop it into a P'UP for me.
If you want to start a bizness with this, just post your work over at customtacos.com. Big community or low-rider yota's over there. You'd easily turn $5k - $8k a conversion.
In case I didn't make myself clear before, I am quite enamored of your truck.
__________________
Peace: CW
Old 09-08-2003, 08:47 PM   #33 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
Matt welcome and thanks for all the information!! I actually passed you today on the top of the Lewiston hill today on my way to Clarkston. We definitly need to get together and talk about this swap!!
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000
Need Toyota Parts? www.davezoffroadperformance.com
Quote:
...why does my IFS have no flex, and what can I do to make it flex???
UKMyers is offline
Old 09-09-2004, 09:16 PM   #34 (permalink)
Staff
UKMyers's Avatar
You guys remember this truck????? I just took a ride in it. Turns out this guy lives about 10 minutes from me. Truck looks very clean he's done a ton of custom work to it... 4-Runner front end, bucket seats, ect.. Anyways it's the first time I've ridden in a Yota with the TRD Supercharger and man you guys are lucky it sounds awesome. I'm not sure how the power compares but I'm pretty sure it's stronger in this rig because it is a little 2WD truck. It seems normal at slow rpms except for a ton of torque but when you hit 3 grand look out. We were on a freeway on ramp going 50 miles per hour and he grabbed third from 5th and stood on it and we spun the tires!!!!!!!!! It will hit 80 in no time flat. I been stuck on the 3.4 swap for almost a year and now with the know how of doing 2 of them right down the road I think I'm outta excuses. Only thing holding me down is finding a beater to use as a daily driver to get to work while mine is down. Boy am I lucky... riding in a Supra Swapped rig and a SC'd 3.4 swapped rig in the same week.........
__________________
UKMyers is offline
Old 09-09-2004, 10:17 PM   #35 (permalink)
(jealous)
I want somebody to do 3.4 swap on Monster Garage. Start the petition now.
__________________
Peace: CW
Old 09-10-2004, 08:29 AM   #36 (permalink)
DavidA's Avatar
OMG...I need to find a donor so I can drop a 3.4 into my '91 4x4!
Plus some money of course.
__________________
2002 Stellar Blue 4Runner Sport Edition
Cold Air Intake
Magnaflow Exhaust
Iridium Sparkplugs
Kenwood KDC-MP628
Blaupunkt Separates in all of the doors
Two RF P2002 amps
Kenwood 12" Subwoofer
My baby: Pics
DavidA is offline
Old 09-10-2004, 03:51 PM   #37 (permalink)
Quote:
Which did you find out to be better?
__________________
1995 4Runner Pewter Pearl V6 Auto
Front Husky Liners, Bushwacker Flares, Manik Tube Steps, White Face Indiglo Gauges, TJM T17 Bumper, K&N FIPK, Scion 6 Disc MP3, Clear Tails, 2.25dia exhaust W/Carsound cat & Magnaflow Muffler, Bridestone Dueler A/T Revo, American Racing Mojave Teflon, Hood Scoop
"There is no limit to stupidity, so I think there's still a lot more I can do."
Shinichi Watanabe on directing Excel Saga
Troudt is offline
Old 09-10-2004, 07:11 PM   #38 (permalink)
Quote:
Hello Troudt, You need to ask UKMeyers. He was the one that rode in my Supercharged truck and drove a Supra 7M-GTE Turbo 4Runner.
__________________
g
MODMAN is offline
Tags
4runner, 5vze, 96, bellhousing, chevota, downy, headers, replacement, speedometer, toyota, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Any one here swaped there cv axles before? Fo by Fo 86-95 Trucks & 4Runners 4 11-02-2006 09:34 AM
Maybe the 3.slow and 22really slow can benifit form this fo_runner 95.5-2004 Tacomas & 96-2002 4Runners 8 08-04-2005 08:35 PM
Swaped CV's, still hearing noise Remi 95.5-2004 Tacomas & 96-2002 4Runners 5 03-16-2005 03:11 PM
3.slow to 3.4L swap questions wellyman 95.5-2004 Tacomas & 96-2002 4Runners 14 06-24-2004 02:15 PM
2009 InternetBrands, Inc.
