Swap Bar Squeak
Swap Bar Squeak
Since installing Addco sway bars on my 98' 4runner I have noticed a loud and persistent squeak from the front of the vehicle. This occurs less so on the freeway and around turns. After investigation, it turns out the noise is coming from the sway bar mounting bushings on the undercarriage. As the vehicle's height moves up and down the sway bar rotates slightly. This rotation against the bushing causes the noise.
Does anyone have any suggestions? Thank you!
Originally Posted by roger
Silicone bushing grease.
I'm not sure if you've used the bushings that came with the addco swaybars or if you bought energy suspension bushings. The ES bushings (greasable ones) have a zerk fitting/nipple on the bracket so that you can use a grease gun to grease the bushings pretty easily.
Ther are also graphite impregnated poly-urethane bushing out there if you want to spend a few extra bones. They claim you will never have to lube them ever to eliminate squeaks.
But this gets me to wondering... couldn't one just dust the inside of the standard bushing with some graphite dust, and let is work it's own way into the rubber/PG?
The mechanic was nice enough to lube them up for me free of charge. But after that, the bushings were SILENT!
Moral of the story, no matter what, you still need grease!
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
DrZero
18
07-24-2015 11:31 PM
