Suspension Lift/Clearance Questions.
Hey everyone, so I have a question. I have a 96 Tacoma 4WD and I am wanting to do some things to it. I am wanting to get this lift http://www.roughcountry.com/toyota-s...it-740-20.html
and it says I can fit 31x10.50R15's on it but if I get 1.5 inch wheels spacers will I be able to fit 33x12.50R15's? I also don't know if I should get 8 inch or 10 inch wide wheels for the tire size.
I ran 31x10.50s on stock trim. With the 4wd set-up that should have been an optional wheel/tire package.
With the lift you will have no problem running 31s.
If you want to go to 12.50" wide tires you should search for 10 inch wide wheels. Spooning them on 8" is asking for bead issues.
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
JookUpVandetti
09-30-2015 08:58 AM
