suspension help
Old 06-24-2003, 02:40 PM
DRUMER77's Avatar
suspension help
thanks for all the advice from everyone.
will the 4wd springs fit on a 2wd?
Old 06-24-2003, 02:44 PM
rimpainter.com's Avatar
Yes. I have some rears if you need them.
Old 06-24-2003, 02:46 PM
DRUMER77's Avatar
cool, are they factory or afetmarket? and how much
Old 06-24-2003, 02:47 PM
What year and model is your vehicle?
Old 06-24-2003, 02:48 PM
Nevermind, I just looked it up, 97 4Runner.
They are stock rear coil springs. Not sure if they would do you any good though. You may want to go with the whole set up. A search will reveal everything you could ever want to know.
DRUMER77's Avatar
97
Old 06-24-2003, 02:50 PM
Give us some more info. What are you looking to do? What would you like the end results to be? Do you want a lift?
More info please.
Old 06-24-2003, 03:02 PM
Los Gatos?'s Avatar
4wd springs defintely give some lift to 2wd vehicles in the earlier generations, not sure about 3rd gens. They are too fancy shmancy for the likes of me. You could probably get 4wd springs all around, or 2" lift in the rear and stock 4wd in the front w/ t-bar lift to clear 32s or something....
Old 06-24-2003, 07:49 PM
DRUMER77's Avatar
i have had the recall done on rear suspension, it still rides rough
i just want a smoother ride because i drive around alot for my job
Old 06-25-2003, 04:51 AM
sschaefer3's Avatar
4WD or aftermarket springs will be stiffer/rougher.
Old 06-25-2003, 08:27 AM
Nolan's Avatar
If his suspension is bottoming out on small bumps like mine was the stiffness of the 4wd springs will not be a problem.
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
ktm192k
10-01-2015 08:47 AM
JookUpVandetti
09-30-2015 08:58 AM
Quick Reply: suspension help
