Surco rack need fairing advice.
I'm trying to find a fairing to use on my surco safari rack.
The Yakima fairing looks pretty solid but it's made for round bars. Will it still work or does anyone have any other ideas? TIA.
I got my old Yakima fairing mounted on my BVG rack. The Yak rack will not work withy my basket, but with some custom brackets I made from parts at the hardware store, I was able to mount the Yak on.
Another possibility is to custom made a fairing from plexiglass you can find at home depot.
They're not that expensive and you can cut them to size and shape with some cutting tools. I am contemplating this route, so I can have a larger fairing than the Yak.
Anyways, hope that helps
Now my only other consideration is if the rack is 45" wide should the fairing be 44" or 50"?
Originally Posted by Ike
I agree, a trip to home depot and/or zip ties would probably work to secure the fairing.
Go with 44". My fairing is wider than the rack, and it don't look quite right. Also, it gets bent up in the wind. But it's plexiglass so it's okay.
Anyways, let me know if you need help.
live4soccer7
05-11-2016 06:52 PM
