| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
supercharger rattling noise on boost
#2 (permalink) |
Sponsoring Member
Yeah... it sounds like ping. My first thought in reading the thread title was that you needed a nose rebuild, but how it reacts to the RPM range leans towards it being ping.
Fire up the FTC1 software and kick the timing down. I trust that you're running 91 octane or better for fuel? And where are you in the world?
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#3 (permalink) |
Yeh I am running 93, ussually from HESS. Living in upstate NY.
__________________
02 Taco 3.4 4x4 S/C'd URD TRD |
#4 (permalink) |
Sponsoring Member
'k... I asked about location 'cause of altitude things. (thanks for updating the location in your profile!).
Anyway... pull out the FTC1 software and a laptop, hit Gadget's tuning guide (it was on the site but I can't find it now - maybe write them?) and get that timing cranked down. Ping is bad - but then I bet you know that.
__________________
#5 (permalink) |
I found the tuning guide here: http://www.gadgetonline.com/U-Tune.pdf
The problem I am having seems to be the same as documented on page 25-26. It says that I should increase the retard in the cells where I hear knock. Does this sound right? What increments should I be changing the values by, 1/2 degree at a time?
__________________
02 Taco 3.4 4x4 S/C'd URD TRD Last edited by brosher; 05-01-2006 at 07:14 AM. |
#6 (permalink) | ||
Sponsoring Member
Quote:
Quote:
I don't run an FTC1 in my truck (I run a similar box from PerfectPower) but in looking at the doc, it looks like a postive number in the field will "increase the retard", and the numbers are relating to degrees of timing. So... I would start tossing whole numbers in there... If you dial in too much retard, then the worst that can happen (to a point) is that you'll lose more power than you have to. I'd work it much like Gadget says... dial in retard until the knock goes away, then see if you can back off 1/2 a degree and still keep it inaudible. Remember though, ping isn't always audible int he cab (especially with the S/C wound up and the deckplate open) so just 'cause you can't hear it doesn't mean it's not there. The point being, erroring on the safe side by having a bit too much retard can save you an engine. Good luck - and have fun!
__________________
| Tags |
| wwwgadgetonlinecomutunepdf |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Different Rattling/clicking noise | BmanToyota | Newbie Tech Section | 3 | 06-22-2007 10:32 AM |
| supercharger surging boost going to 8psi | bakes | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 04-25-2006 05:16 AM |
| "rattling noise” from Catalytic | progress4m | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 09-11-2005 08:54 AM |
| Ayudame. Rattling noise, not sure what it is. | chuckd | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 08-17-2005 11:01 AM |
| what could this rattling noise be | jtm994 | Maintenance & Repair Archives | 14 | 04-21-2005 07:28 PM |
