supercharger oil
Old 07-18-2008, 12:32 PM
johnw999's Avatar
supercharger oil
I have a 2nd gen supercharger, and I ordered a the TRD oil change kit for it. The instructions say to remove the supercharger for the oil change. I really don't want to spend so much time doing that. Anyone change the oil without removing the supercharger? I assume that oil will spill out if I remove the drain plug. Maybe I could jack the front end up to keep the supercharger at an angle for the oil change.
Old 07-18-2008, 12:44 PM
pfdaxe's Avatar
Read this link: http://www.gadgetonline.com/SuperNose.htm
Just syphon the oil out. You don't have to pull the s/c. There was very little that came out when I changed mine. I syphoned what little there was and then I unbolted and pulled the nose and wiped it all down. Then put the nose back on and refilled with oil.
Old 07-18-2008, 07:48 PM
Andrey's Avatar
How many miles do you have on your S/C? I believe that oils lasts for at least 100k w/o need to change.
calderp
Engine Swaps
08-16-2016 05:15 PM
anniesball
07-29-2015 11:46 AM
calderp
07-27-2015 09:58 AM
mengquis
07-13-2015 10:39 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: supercharger oil
