Stupid lube question
Old 07-07-2003, 03:57 PM
Citykid's Avatar
Okay, I'm a champ at replacing all the fluids and basic maintance up-keep. BUT, I still need to go to the stealership for all joints and fittings to be lubed. I just do not know what (and where) needs to be re-lubed. :pat: And the type of grease to use. Is there a diagram anywhere that shows all the points to go at? Or does anyone have any suggestions? Thanks for not laughing too loud.
Old 07-07-2003, 05:55 PM
metal22lica's Avatar
heres a link but im not sure how much it will help you. i dont really think it will be too much different.
Old 07-07-2003, 06:51 PM
Citykid's Avatar
Thank you very much.
Old 07-07-2003, 07:38 PM
Citykid's Avatar
Is a Zerk a bolt that is to be removed so you can shoot some grease in there?
Old 07-07-2003, 07:48 PM
keisur's Avatar
do not remove these, mostly because they are press fit into the ujoints. they have a detent ball in the tip that is like a check valve, it only lets grease get pumped in, not out. gotta get a grease gun and a flexible grease gun hose and 'snap' the tip onto the zerk's and then give it a couple maybe a few pumps. there's one for each ujoint on the drive shaft and one for the double carden. I believe there are 5 maybe total on the rear drive shaft and 2-3 on the front, I can't remember off hand becauese I usually just start at one end of each shaft and work toward the other end until all have been lubed so I don't count.:pat:
EDIT: I forgot to mention the zerks that lube the slip yokes too.
Old 07-07-2003, 08:02 PM
Citykid's Avatar
Ahhh, that would have been ugly. Gota go get a gun tomorrow. Uh, grease gun that is. Thanks.
Old 07-07-2003, 08:30 PM
keisur's Avatar
yes that bit me in the keester once as I was removing the driveshaft to replace an input shaft seal. I put a prybar in through one of the ujoints and began loosening the four companion flange bolts, and ~snap~! oh I thought to myself, but luckily it just pulled out and didn't snap off. I just wiped some gasket stuff on the surface and pressed it back in. I only did that because I plan on replacing all my ujoints sometime anyway and I figure that will get me by until I do.
Old 07-08-2003, 07:28 AM
02Runner's Avatar
Hey city kid, if you can buy Chevron Delo or any other type of EP grease. Ep=Extreme Pressure, or extreme duty grease. The consistency is greater, will provide better lube for a longer time and will reduce wear. It won't be as useless as say a cheap "red-tack" grease. Both at work (John Deere 450 and Case 921, Excavators and FE Loaders) and home I use EP. Cheap grease is thin and near useless, not totally but close. Others may argue, but just be sure to grease, regardless of the type.
I grease my vehicles at least once a month. I am in SW Fla and work in a fill pit, sand and rock.
Old 07-08-2003, 07:39 AM
keisur's Avatar
do you have your dwarf do it for you?
Old 07-08-2003, 07:49 AM
02Runner's Avatar
Dude, that is F-ed up. Of course not, he's a "union dwarf"
Old 07-08-2003, 03:10 PM
EDGE's Avatar
How often should one grease the driveshafts, every 5k or 10k
02Runner
anything besides the zerks on the driveshafts that need to be greased, I counted 6 is that right or did I miss some
Old 07-08-2003, 03:21 PM
Yoda's Avatar
I would grease about every 5 k or anttime I have encountered water deep enough to hit the driveshafts/steering components. My 71 Landcruiser has 13 grease fittings I can think off.
I use an exstreme pressure synthetic grease as it "clings" better to the parts I grease and doesn't wash off.
Old 07-08-2003, 03:44 PM
Guest
Yoter's Avatar
You said it!
hey don't let the boss hear you say that. I better not say his name, I dont want his attention. :pat:
Old 07-08-2003, 04:18 PM
keisur's Avatar
02Runner
if it's 4x4 there's more than six.
calderp
Engine Swaps
08-16-2016 05:15 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
altydog
07-28-2015 10:20 AM
calderp
07-27-2015 09:58 AM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: Stupid lube question
