YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 03-08-2009, 12:52 PM   #1 (permalink)
Personal Sales Rating: (0)
Stumbling/Hesitation from 1500-2000rpm
So i noticed a slight hesitation a few weeks ago, and it has gotten worse. Around town it is really noticeable. Not consistently, but often enough for it to irritate me. Now I think I noticed it at highway speed. It could be my imagination, so I'm not 100% sure on that, but around town it's definately there.
Initially I hoped it was simple, so I changed spark plugs for NGK Iridium, cleaned MAF, cleaned throttle body, and threw in a bottle of seafoam. Still feeling hesitations.
I'll be changing the fuel filter and plug wires tomorrow. I don't think it's the plug wires because I put a set of NGK wires in about 30-40k ago but I have a spare set so I figured I'd give it a shot. The truck has around 156k now so I just hope it's nothing worse. I'll also try running some fuel injector cleaner to see if it might be a clogged injector or something.
That being said, my question is, could it be the torque converter locking up? I know I need to replace my cv axles, and for a minute I thought maybe it could be the axles about to grenade, but I don't know. How could I check if it's not electrical and maybe something worse like the trans/torque converter?
Oh and I haven't been lucky enough to have a code thrown. That would be just giving me the answer.
Any help would be appreciated!
roadtripgeorge is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 03-08-2009, 01:20 PM   #2 (permalink)
rbh261's Avatar
I hope that you find a simple fix. I had a similar problem. I replaced all the simple stuff with no results, new coils,plugs,wire,TPS,O2 sensor and cleaned MAF. I heard off a problem some were having from an incorrect timing belt install. I pulled the front of the engine down to inspect the timing belt and accessories. I found that the belt was installed incorrectly and the crank bolt wasn't torqued properly. My crank gear had moved around enough that it had worn the woodruff key and the keyway inside the gear. Replaced the gear,belt,water pump,thermostat and crank sensor. Problem solved.
__________________
'98 4-Runner
SR5 V6 Automatic
Intake elbow removed, Sony head unit, Sony Class-D amp, Sony 10" sub enclosure and F&R components
Brad Hall
Assistant Service Manager
Nelson Automotive Group
201 Commonwealth Blvd.
Martinsville, VA 24112
276-638-2331
www.autosbynelson.com
rbh261 is offline
Old 03-08-2009, 01:46 PM   #3 (permalink)
Threadstarter [OP]
thanks for the help. I'll give that a check. The stealership put my timing belt/water pump on at ~100k. Could it really be time to do it again?
Old 03-08-2009, 06:00 PM   #4 (permalink)
rbh261's Avatar
I wouldn't think it would be time again, but they may have used the old torque specs for the crank bolt. I had my first suspicion when I put a timing light on it and the timing was jumping all over the place. I jumped pins the pins in the diag plug under the hood like you would on a Yota with a distributor. It lets you check base timing.
__________________
'98 4-Runner
SR5 V6 Automatic
Brad Hall
276-638-2331
rbh261 is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
1500, 15002000, 2000, 2000rpm, 4runner, crankshaft, hesitation, rpm, rpms, runner, stumble, stumbling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Stumbling/Hesitation during acceleration Lifelongtoy 86-95 Trucks & 4Runners 58 11-30-2010 09:53 AM
engine wont rev past 2000rpm? carova_kevin 86-95 Trucks & 4Runners 17 08-12-2008 06:02 PM
Very WIERD hesitation/stumbling problem LS1Steve 86-95 Trucks & 4Runners 2 03-26-2007 10:40 AM
Stumbling? ShortyzKustomz 86-95 Trucks & 4Runners 5 03-22-2007 12:10 PM
Severe stumbling/hesitation and stalling (Longish post) ChallengeTheSea 86-95 Trucks & 4Runners 21 02-03-2006 04:50 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
