studs vs. bolts for HG
Old 12-28-2003, 01:13 PM
okidoc's Avatar
Anyone changed to studs (DOA kit) instead of using the head bolts for the 3vze? I'm looking at a HG replacement and don't plan on doing it again any time soon. Will studs help prevent further probs? Any tips when installing studs?
Old 03-07-2004, 06:34 PM
MTL_4runner's Avatar
Yes the studs should help the problem from happening again.
Old 03-07-2004, 06:53 PM
toy283's Avatar
I use studs whenever I can. Heads, bearing caps, etc.
Old 03-07-2004, 07:02 PM
BruceTS's Avatar
Whenever I teardown an engine, I replace the head bolts with ARP studs.....
Old 03-07-2004, 08:47 PM
Fahrenheit 451's Avatar
Apparently, the consideration for the v6 with studs is being able to get the heads off again. On a series of posts on alt.autos.toyotas.trucks somebody did the HG on their v6 and I had suggested the possibility of using studs. When they did the job, it was their opinion that it could wind up being impossible to get the heads off again without pulling the motor due to clearance issues in the engine compartment. I thought you could probably double nut the stud and pull it out, but they felt that there wouldn't be enough enough thread exposed to get two nuts on it.
Old 03-08-2004, 06:53 AM
Gadget's Avatar
If you go with studs, get "broached" studs.
The broached studs have a allen hex cut into the top of them that will allow you to remove the stud in the event you need to pull the head while the engine is in the vehicle. In that case you will need to remove the studs before the head otherwise you can not lift the head up high enough to clear the studs without hitting the firewall.
Gadget
Old 03-08-2004, 07:51 AM
SLC Punk's Avatar
Me too. I am having ARP head studs installed on my Celica's engine.
Corvoid
09-14-2015 10:10 AM
Pocoyota
09-08-2015 02:41 PM
Jwp1
09-06-2015 11:03 AM
eggens
09-05-2015 12:16 AM
Aaron Logan
09-03-2015 08:08 AM
Quick Reply: studs vs. bolts for HG
