Stuck in the middle of body lift, a little help please :)
Old 03-28-2009, 11:16 AM
Punch's Avatar
I have a 2" 4crawler body lift kit. I've searched around and got the basic idea on the 5 bolts on each side, steering extension, radiator brackets and bumper brackets. I've removed all 5 bolts on the right side and have attempted to lift the body several times off the frame in several locations and I CAN NOT GET THE BODY OFF THE FRAME! What am I doing wrong? I've lifted at the body quite a bit and it only lifts the whole truck when I do it. Well I'm stuck till I get some sugestions, so please help out! Wanna get my rig set before dark!
Ryan
Old 03-28-2009, 12:26 PM
MillerPKA's Avatar
Get wd-40 or pb blaster and shoot all of points of contact. try a chisel punch and lightly tap the gaps
Old 03-28-2009, 12:28 PM
TOYOTA 1's Avatar
did you loosen the other side first?
Old 03-28-2009, 12:36 PM
Punch's Avatar
Talked to Wabfab that was my problem.
<<<<Newb
I read in several threads about doing one side at a time so I litterly only did ONE SIDE. Yeah I'm a newb with these body lifts but I have the right side lifted now . Now I'm going to attempt the steering assembly and left side. Thanks for the two responses guys .
Old 03-28-2009, 12:39 PM
TOYOTA 1's Avatar
hahaha i knew it!
im glad you got it
post some pics after the install!!
Old 03-28-2009, 01:58 PM
aaron26889's Avatar
that happened to a buddy of mine he had to drive around with the bed lifted 3 in higher then cab.. we had to cut the bolts out and get new ones before we could finish..
Old 03-28-2009, 02:02 PM
waskillywabbit's Avatar
Vita sine litteris mors est.
Post some updates.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Cabell
07-24-2015 12:14 PM
Backcountry411
07-24-2015 08:06 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Stuck in the middle of body lift, a little help please :)
