Strugglin when starting up
Hey guys I have a 2000 runner with 93K miles, a couple of days ago the truck started to struggle when starting up like if the battery was dying. I cleaned the posts cause they had corrosion, but that did not help much. I don't think is the battery because the truck is still running, I have not check the charge thou. No issues after the truck fires up. Any body has had this issue? any suggestions? Thx
Dying battery
failed alternator (dash charge indicator should be staying on)
bad battery cable to the starter
Battery cold be barely alive, just enough to barely start truck. Once the truck starts up, you don't even need a battery, if alternator is good. Definitely have to have battery checked. It's such simple procedure. If your battery's around 3 years old, it could easily bad.
If it's around 3 years old, probably needs replacement anyway.
ZONAYODA
07-13-2015 07:17 PM
Poncho0206
07-10-2015 06:21 PM
