Stripped MAF screws
Stripped MAF screws
Hey to all, was trying to do the MAF sensor cleaning thing and like so many others, found one stripped screw and I did the other. So no cleaning done. I read the different threads on how to get them out etc. But no mention that I noticed on where to get replacement screws. talking auto parts/hardware store, vs. a junk yard. any comments here would be appreciated. thanks in advance
I've only written a few threads and responses and everthing so far has been very helpful.
you're screwed. sell your truck and move on.
okay, actually i once lost a MAF screw. i went to a couple hardware stores, and after much searching, found a suitable screw. not sure where you live, but around here there's a hardware shop that has pretty much every size/type of screw/bolt possible. so you may have a store like that in your area. or, try searching online.
Stripped MAF Screws
thanks for the heads up, actually that's how I srtipped the second screw, with a screw extractor. I'll figure it out though. tap and drill, probably. thanks again.
Location: Far western Kentucky (transplanted from central PA)
Ditto on my 2000. I was able to drill the head off of the screw and used a small easy-out, then went through my "screw jar" and found one that fit. Put some anti-oxidant on the threads.
Stripped MAF sensor screws, FIXED
Hey to all, thanks to all who responded to my call for help. After the "check engine" light came on again I decided I really needed to get that sensor out and see if that was the problem. Had to use a drill for the screws and then an easy out. All said and done, was a ten minute job at best. I took out the sensor and one side looked spotless and the other looked like, well crap, grey dusty dirt!! took out the contact cleaner and q-tip and had at it. re- assembled with new screws** and pulled the EFI fuse to reset the light, stated her up, seems to run smoother, we'll see if that was the problem.
** for future reference, got the screws at Home Depot/Lowes, 4mm by 10mm, beveled machined phillips screws for about 35 cents.
Originally Posted by MTL_4runner
If the light comes back on you should take it in to get the codes read.
I bought an OBD II reader on Ebay for about $15. It's come in handy but it doesn't clear the codes - even though the instructions say it will. The more annoying part was when I finally found out what was making the code happen on my wife's Highlander..... there's an EGR line that runs RIGHT next to the oil filter and I was bumping it loose during oil changes. Arrgh!
Stripped MAF screws fixed
Hey thanks for all the help and advice, I went to Auto Zone and because I had pulled the EFI fuse they told me and showed me that there were no codes to read. The EFI fuse apparently clears the codes. Also I just bought a Actron Code Scanner off of Amazon.com model 9145, that reads ' em, explains 'em and clears them. Should be here this week. again, thanks. EDH
zytra
01-24-2019 03:16 PM
hiluxinargentina
09-30-2015 05:51 PM
