| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
SOLD??? Never 1990 Automatic V6 4WD SR5 4Runner Mods: Downey 1.5 HDs, Aisin Hubs, CD, CB with a 4' Firestik, Husky Liners, Maglite Mod, 2nd Gen Airbox Mod, K&N filter and a Smittybilt Brush Guard with 4 lights. Next: Rims? Shocks? Exhaust? PICS -Corey |
#2 (permalink) |
lug nut
is it a front or back one? the rear is real easy.
__________________
jason liskey-----85 sr5 toyota 4runner 22re 5 speed 5" lift 33 " tires. for a trail rig 89 sr5 short bed 22re 5 speed for a daily driver 86 toyota dually 22re ex camper now a flat bed for a parts hauler/tow rig. soon to be a 5 speed |
#3 (permalink) |
its a rear one..
__________________
#4 (permalink) |
its easy
he would not take it off because he was afraid it would snap off flush with wheel. there easy to do your self heres how. take your tire and drum off. get a punch and hammer and pound out the broke stud. to install the new one you'll need a impact gun for the air compressor to draw the new one in. has splines that fit tight in axle flange. slide the new stud threw the hole and put a couple washers on it with a plain lug nut on backwards then tighten it with gun till the splines are pulled into axle. the back of lug stud will be flush with axle. you mite have to spin axle around to find spot where stud will fit with brakes still on. hope that helps.
have fun
__________________
#5 (permalink) | |
Re: stripped lug nut???
Quote:
__________________
Front: 4.88's w/ ARB Locker Rear: 4.88's w/ ARB Locker Lift: Suspension - F: Sway-A-Way Coilovers; R: OME Coils/Shocks Body - 2" HDPE Pucks w/ higher strength bolts Recovery: TJM T15 Bull Bumper w/ Warn M8000 Winch Lighting: Lightforce Striker 170's Multimedia: Kenwood DNX5120 DVD/GPS/USB/iPod/SAT Sound: Focal 165A1 Component Front w/ Focal 130CA1 Rear Infiniti Kappa Perfect 10.1 Sub 500W RMS amp for fronts and rears; 500W RMS amp for sub Power: Optima Blue Top 1400 Watt Power Inverter |
#6 (permalink) |
If the torque on the air wrench was set for "MAC Truck" there might be a problem.
#7 (permalink) |
stripped lug nut
this happens from the last person that rotated the tires tightening them way to much.:cry: be glad you don't have a old solig axle truck you have to pull the whole rotor off to change the front stud
it takes almost 2 hours to do
__________________
#8 (permalink) | |
Re: its easy
If it breaks off flush it's easy, if it strips out in such a way that the nut gets stuck on and just spins freely (had it happen) you're gonna have to cut it off first before you can punch the rest of the stud out.
Quote:
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!" |
#9 (permalink) |
man..so i just wont be able to take the lug nut off and replace it with a new one? hmm...anyone in the area want to help me? i will let you touch my aisin hubs...please..anyone..someone..
__________________
#10 (permalink) |
You may, but if the nut's screwed up chances are the stud is as well. Or it may just be seized a bit and the guy's a :chicken: Put it this way, if it breaks it breaks. You still have 5 good ones on that wheel so it's not like you can't drive it to a shop or wherever to get help replacing it.
__________________
#11 (permalink) |
Had this problem several times - always caused by some moron putting the nuts on with the impact wrench. Always, Always, Always start the nuts by hand. If you must use an air tool after that, use a socket drive or imapact on a low setting. Once the nuts are on all the way, snug them up with a torque wrench.
| Tags |
| 1516, 1990, 4runner, fit, focal, lug, lugnut, nut, nuts, remover, rims, snap, sr5, stipped, stripped, tools |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Tokico top nut stripped off | seanz0rz | 95.5-2004 Tacomas & 96-2002 4Runners | 40 | 04-27-2007 08:39 PM |
| 02 sensor install.... stripped nut | hill | 86-95 Trucks & 4Runners | 5 | 02-22-2006 10:14 AM |
| Fuel filter nut stripped | Citykid | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 06-13-2005 09:05 PM |
| Lug Nut Bolt Stripped | metal22lica | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-22-2003 04:41 PM |
