Strawberry milkshake prevention
Old 10-22-2011, 03:29 PM
Jay1's Avatar
I did the search for strawberry milkshake and didnt find what i was looking for. Im looking to see if anybody has used a good radiator to hook up to the tranny cooler lines. My 4runner has 186,000 miles and i dont want problems with the stock radator. Im not sure if its been replaced or not.
Old 10-22-2011, 06:36 PM
rworegon's Avatar
The radiator I picked up from www.performanceradiator.com has been doing a good job for the past 3 years in my Tacoma. That said, I also run an external cooler (Tru-Cool 4454) and do not use the one in the radiator.
Old 10-22-2011, 06:39 PM
Evilmunkey's Avatar
Best prevention is an external Trans cooler... but I too want to upgrade to a better radiator and do an external cooler just to nix the whole S.Shake
Old 10-22-2011, 07:44 PM
Doug18's Avatar
I Run a Hayden 1405 trans cooler Ive had it on there for about 4k miles now and no problems
Old 10-23-2011, 11:32 AM
Jay1's Avatar
Thanks for the replys. If i put in a trans cooling radator, the stock radator will be fine with out the anything hocked up to trans cooler lines?
Old 10-23-2011, 11:47 AM
BMcEL's Avatar
Yes just cap it.
Old 10-23-2011, 11:48 AM
rworegon's Avatar
Yes, the radiator will be ok. However, to prevent dumping your coolant if the radiator/trans cooler interface should fail, clamp a piece of hose between the two trans hose ports as in post 13 here:
https://www.yotatech.com/forums/f2/r.../?ref=esp-link
or cap both ports as said above....either works.
Old 10-23-2011, 01:15 PM
bone collector's Avatar
the best strawberry milkshake prevention is to put in a 5 sp... sorry somebody had to say it! just kiddin keep truckin
Old 10-23-2011, 03:09 PM
mwc0404's Avatar
I prevented the shake by changing the radiator to one with without a built in trans cooler and ran an external hayden and its worked great!
justdifferentials
Just Differentials
06-13-2022 07:40 PM
shisha1999
03-03-2016 07:09 PM
hiluxinargentina
09-30-2015 05:51 PM
charlie_fong
09-27-2015 10:06 PM
AustinTaco
09-18-2015 08:58 PM
Quick Reply: Strawberry milkshake prevention
