strange sound when turning.
This only happens after a cold start. When I turn the steering wheel it makes a noise similar to a sick owl hoot (or maybe a sea lion). I can kind of feel it it in the steering wheel. After the truck warms up it no longer occurs. Any thoughts are much appreciated.
Jeff
Jeff
:pig:cake, sounds like a belt issue (fluid is stiff when cold, pump harder to turn, belt slips a little - my dime-store logic anyway)
BBB - if yours sounds like a creaking, all you have to do is lube your steering stops.
Originally posted by BigBadBlue
Tankyuh Ceb I will do tnite while on the clock ofcourse.
Who actually works at work anyway?? I try to as little as possible.
Originally posted by mertztr
Maybe the power steering pump or fluid level? Or a loose belt?
Thanks guys...
Originally posted by Toyo_Runner96
So Tom are you for sure gettin the job in PA? If so you gotta make a stop in Indiana and wheel with us Attica boyz.
Cool...now the next question is, where did all the fluid go??
Bourbonblues
12-15-2017 05:43 PM
potatopants
09-15-2015 06:26 AM
