| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Strange sound near passenger side floorboard
__________________
Buy my 4runner: http://www.yotatech.com/f108/lifted-...r-sale-148082/ 97 SR5 4runner, Automatic. 2.5" Donahoes, Total Chaos Upper arms, Custom swaybar links in front. Rear Downey 3.5" rear coils, Bilstien shocks, 2" 4Crawler Body Lift. Sonoran rear Panhard bar, Stubbs Sliders.American Racing Teflon Victor rims wrapped in 315/75/16 Pro-comp Xtreme AT's, Bushwacker Flares and a bunch of other stuff. |
#2 (permalink) |
could be stuck on but doubt that. pull the heater fan fuse. im not sure exactly were it is on the newer 4runners but it either next to the fan unit behind the dash or the kick panel next on the drivers side. see if it turns off. When you open the vents while the truck is running and no power to the fans does air blow through? when you do this make sure the air is set to circulate through the cab not comming from outside.
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more. Might as well start reading this if ya want know more |
#3 (permalink) | |
Quote:
__________________
1998 4runner |
#4 (permalink) |
Hopper nailed it! I do have rear heat. At first I looked at the rear heat and the slider was in the off position so I thought nothing of it. Someone had pushed the high/Low button causing the fan to run up front!
Thanks for the help, Bryan
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| strange rattling noise around the front passenger side kickplate | spacewrangler | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 09-10-2005 03:20 AM |
| Possible for Passenger side automatic window too? | dallasyoung | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-30-2004 10:55 AM |
| Passenger Side window | Goose | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-02-2004 09:06 AM |
| Passenger side rattle.. | az4x4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 05-22-2003 05:22 PM |
