strange rear end and or parking brake problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-07-2008, 12:50 AM   #1 (permalink)
89macrunner's Avatar
So lately my truck has been acting kinda weird. I just had a new FL caliper and new pads installed, as well as a full brake flush. My brake idiot light doesn't turn off even though the parking brake is all the way off.
since than my truck has been acting strange from a stop. it feels like the truck has the parking brake on when I am stopped. When if I give it gas the revs go up but the wheels don't move untill i give it enough gas. when this happend i feel a little bump in the rear end and I move forward. The rear doesn't get hot, and I don't think the brake drums really are eaither. Do I just need my rear brakes adjusted? if so how do i do it?
Problems I can see...leaky rear axle seal..very small leak though and it hasn't been going on long. Also, I have a torn outer CV boot on the drivers side (not related at all)
thanks
__________________
Daily Driver: 2007 Windsor "The Hour" Fixed Gear 250 miles
Crouch Rocket 2005 Felt F80 1100mi (purchased new in Jan 2008)
2006 Mazda3 GT
2000 TRD Tacoma..Bought back and crushed
1988 4Runner SR5 V6 5 speed..sold
89macrunner is offline
Old 04-07-2008, 03:35 AM   #2 (permalink)
mjwalfredo's Avatar
Send a message via AIM to mjwalfredo
Maybe the leaky axle seal doesn't see too bad because the shoe is soaking up all the gear oil and consequently resulting in the symptom you've got? I'd get the leak taken care of and then make sure the CV axle is also not leading to any added resistance in the drive line too. I bet your problems will be gone after fixing both and of course adjusting the rears as well...
__________________
-Marcus
1997 4Runner Limited 4x4, E-Locker, Bilstein HDs, Air Springs, Deckplate Mod, 265/75/16R Bridgestone Deuler A/T Revo
mjwalfredo is offline
Old 04-07-2008, 05:00 PM   #3 (permalink)
brandyn85's Avatar
Send a message via AIM to brandyn85
i have the same issue... i thought it was the wheel cylinder so i replaced that and it was good for almost a full day. only seems to do it when its colder... and now that i think about it there was what seemed like some grease or oil in the drum... but it seemed to be pretty dry... ive never seen this on any of my older toyotas... just the 99
__________________
i like to picture my jesus in a tuxedo t-shirt, cuz it says i want to be formal, but im here to party!
99 toyota 4runner limited
ISR mod
Deck plate mod
flomaster exhaust
brandyn85 is offline
Old 04-08-2008, 01:14 AM   #4 (permalink)
well im taking it to the stealer to have the seal fixed sometime this week.
they actully quoted me a better price than any shops in the area!
__________________
2006 Mazda3 GT
Old 04-08-2008, 02:54 AM   #5 (permalink)
mjwalfredo's Avatar
Are they putting a new bearing on? I replaced the bearing at the same time just because if it is leaking bad, the gear oil can wash away the grease for the bearing.
It really is an easy job to replace the seals yourself and bring the axle in for a new bearing, FYI.
__________________
-Marcus
Old 04-08-2008, 02:57 AM   #6 (permalink)
I live at the dorms and last time i had my truck up on jackstands for about 35 minutes before i got yelled at. Doing my own work at this point is not an option. Ill see what they will charge for a new bearing, but I don't think ill need it. this problem hasn't been going on for very long.
My front CV boot is the thing that scares me cost wise...
__________________
2006 Mazda3 GT
Old 04-08-2008, 03:51 AM   #7 (permalink)
mjwalfredo's Avatar
If the leak is not bad then it'll probably be fine.
College... My truck went through some rough times then. I'd either fix things half assed or it I would wait until absolute disaster would strike before I took it in to be worked on. I'm so glad I've got my own place with a garage now!
Good luck!
__________________
-Marcus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Strange Brake Problem. I have tried just about everything... ugadawg95 95.5-2004 Tacomas & 96-2002 4Runners 16 12-12-2007 03:40 PM
Strange Brake Problem with Front Brakes 'Sticking' ugadawg95 95.5-2004 Tacomas & 96-2002 4Runners 3 11-21-2006 06:05 PM
All Pro Rear Disc Brake Kit removes parking brake! RunnerUp 95.5-2004 Tacomas & 96-2002 4Runners 12 09-28-2006 01:26 PM
Parking/Hand Brake Problem... I think maguirre 95.5-2004 Tacomas & 96-2002 4Runners 6 09-11-2006 10:15 AM
Strange brake problem L33T35T 4Runner 95.5-2004 Tacomas & 96-2002 4Runners 4 08-13-2003 09:16 PM
2009 InternetBrands, Inc.
