Strange noise when I turn.
Old 10-23-2008, 11:58 PM
ato178028's Avatar
Sometimes when I turn I hear a noise that I can only describe as a marble or rock rolling on a truck bed. I have a 4runner so that is not possible. I recently had some differential service done so im wondering i they messed that up and the noise is a result of it.
Old 10-24-2008, 12:06 AM
TC4RNR's Avatar
i had a VERY slow leak on the driver side axle seal, it drained the gear oil out a bit over time, also cause the wheel bearing to fail. i spent 3 days just to found out where the noise was coming from the rear wheel.
ask a frind to rock the vehicle while you get under see if you can find the problem.
Old 10-24-2008, 12:17 AM
ato178028's Avatar
Will try this, thanks, it sounds like it is coming from the rear though.
zytra
01-24-2019 03:16 PM
Davebarbier
11-03-2015 03:28 PM
zombie_barbarossa
10-02-2015 10:54 PM
JPV
09-28-2015 03:15 PM
Quick Reply: Strange noise when I turn.
