Strange noise
Old 02-21-2009, 01:17 PM
Mulkey's Avatar
Strange noise
A strange noise is coming from underneath when barely on the gas. A rattling noise. Nothing when in park and hitting the gas just when the car is moving and barley touching the gas. Muffler/exhaust pipe????? Pretty freaking loud. What's everyone's best guess? Just got it back from the shop- new timing belt/water-pump/shocks-springs/bushings and spark plugs.
I actually heard it before the work was done but now it seems louder. Maybe the exhaust heat shield????
Old 02-21-2009, 01:22 PM
toyota4x4907's Avatar
u-joints? loose exhaust hanger? muffler bearings?
Old 02-21-2009, 01:24 PM
rock slayer's Avatar
cat???
Old 02-21-2009, 01:26 PM
yeah i agree those dang muffler bearings gotta watch those cause when they go it usually messes up your piston return springs
Old 02-21-2009, 01:59 PM
Mulkey's Avatar
I just filled up the muffler fluid so I doubt it's the bearings.
Old 02-21-2009, 02:06 PM
haha i was Serious about the catilidic converter tho my friend had a strange rattle and it turned out that the inside of his cat was falling apart
Old 02-21-2009, 02:26 PM
Mulkey's Avatar
That's what it sounds like or the heat shield rattling and it's coming from that area.
Old 02-21-2009, 02:31 PM
we took it off and literally dumped out the contents
Old 02-21-2009, 02:58 PM
have someone drive very slowly so you can walk beside it and listen for the noise. Try to determine where abouts its coming from, ie, front, middle, rear, higher, lower. Also, if the noise changes with increase in speed.
zytra
01-24-2019 03:16 PM
Davebarbier
11-03-2015 03:28 PM
zombie_barbarossa
10-02-2015 10:54 PM
JPV
09-28-2015 03:15 PM
Quick Reply: Strange noise
