Strange Intermittent Parking Brake Light
The parking brake light on my '99 Tacoma mysteriously comes on when I step on the gas, then goes off when I'm coasting. This only seems to happen when it's cold outside! Has anyone else had a similar problem?
Thanks - Ian
Thanks - Ian
First thing I'd do is check the brake fluid. Low fluid could cause that to happen. Also, you either need to do a brake job or find the leak in your system. Most likely it'll be worn down pads.
Second thing I'd do is check your parking brake to make sure its fully disengaged and that it stays where you put it. If it just barely hits the switch under the dash and has a little bit of play that could also turn on the light.
-Ted
1 Post
Low brake fluid. Usually it's low because the brake pads/shoes have worn down. The pads/shoes may still be fine but they are riding further in now and the fluid fills the wheel cylinders causing the low fluid level. Top off the fluid but also have the pads and shoes checked.
ashersullivan88yota
01-18-2022 05:37 PM
terminator
07-27-2015 07:13 PM
CanRunner
07-20-2015 01:29 PM
Johntom240
7
07-13-2015 12:18 AM
