Strange Brake Problem. I have tried just about everything...
I am having a really strange problem with my brakes. I have a 99 Limited with ABS. I have noticed 2 different scenarios when this happens. First, If I encounter loose gravel on top of pavement, and I am braking normally at an intersection. My brakes feel like they give out and I get this back pressure that 'fights' my foot up and down until I completely stop, then it is fine. Second, I have this one intersection near my house that is sloped about 20% right to left...like this /. The road continues but my road is to the right in the middle of the turn. When i go to turn right at the intersection, essentially going over a hump because the road drops off on the other side. more often than not I get the same occurance. The right front tire never leaves the pavement but the weight is shifted to the left substantially. It feels like the pressure is reversed and i get this back pressure that makes the brakes shudder. If that makes sense. I can feel the brake pedal pulsating backwards and at that time, there are no brakes for a few seconds. Kinda scary. I had this happen on slightly wet pavement one other time while stopping at an intersection. It feels like the ABS doesnt engage. I have replaced the calipers, pads, rotors, brake lines and had the brakes bled numerous times. Things I am considering are master cylinder, brake booster, and possibly some kind of vacuum problem. Anyone experienced this strange problem?
I have had the same thing happen. I think the shuddering IS the ABS kicking in. But thats just a guess. When I am stopping and hit a bump or wet roads I think my ABS kicks in a bit early and does what you described. If anyone has any answers to this that would be great.
Yeah, your descriptions sound like normal ABS operation to me. Your post count is pretty high so I am betting that you know how ABS works but the system will vibrate the pedal to let you know that it is reducing the amount of brake being applied to keep the wheels from locking up.
This is a little off topic but people complain that ABS sucks and locking up the wheels will stop them faster. While this may or may not be true, it is true that you cannot change direction while your wheels are not rolling at all. That is the beauty of ABS, it will at least give you chance to steer clear of any obstacle in your way.
Well I guess. It just seems squirly to me. I guess the ABS is freaking out because there is nothing for the tires to grab onto while traversing the gravel and it applies the back pressure to comensate for that?
same thing happened to me last year when hunting...i was goin about 55 on a paved road and needed to turn around, so when i had slowed to about 15-20, i eased off the road while mashing the brakes, and once i hit the loose gravel on the roadside, it felt like it was shuddering...but good to know it's normal operation of the ABS, as it kinda scared me... lol!
The purpose of this is to allow the driver to maintain steering control under heavy braking and, in some situations, to shorten braking distances (by allowing the driver to hit the brake fully without the fear of skidding or loss of control). Disadvantages of the system include increased braking distances under certain conditions and the creation of a "false sense of security" among drivers who do not understand the operation and limitations of ABS.
from: http://en.wikipedia.org/wiki/Anti-lock_braking_system
Sometimes the ABS gets overly aggressive, not sure how common this is on 4runners, but on Land Cruiser's it is common to go over a speed-bump or pothole and be gently on the brake and the ABS goes nuts and then you freak out because the vehicle doesn't want to stop. Taking the ABS sensors out and cleaning them off (they are a magnet and will gather up any metal shavings/pieces wandering around in the birfield grease)...however, that of course is only for a Land Cruiser. Though I guess the 4runner ABS sensors could have some random metal bits on them, though I don't know where they would come from.
My 4runner has done something similar, and on a slushy road it's a bit of a pain, it does help to just push the brake pedal down harder, at least in my experience...still pulses, but the vehicle stops better/quicker than trying to ease up on the brake pedal pressure.
theking11863
03-19-2016 09:36 PM
Dennisx2
08-04-2015 01:26 PM
