Stop/reverse to disengage??
Old 01-08-2004, 04:26 PM
cctk2's Avatar
In the late model Tacos, I read you have to either roll the truck backwards or drive it in reverse a tad to disengage the 4WD?? Advised? Required? Yuck.
My good ol 68TLC with the 4WD/transfer case operated via diaphram off vacuum, I could switch back and forth 2WD/4WD (at slow speeds) without ever missing a beat. I mean, having the inertia means everything sometimes, yanno?
Thoughts?
Old 01-08-2004, 04:32 PM
AverysDad's Avatar
do you mean the ones with ADD or manual hubs??
my taco has manual hubs and ive noticed that if im driving and shift back to 2WD i sometimes have to let off the gas or give it a quick blip to make it switch.
if im at a stop and put it back into 2WD i sometimes but not often have to back up a tad then go forward to make it switch.
my wifes 95 4runner with ADD has no trouble at any speed going back and forth to 4WD.
Old 01-08-2004, 04:41 PM
cctk2's Avatar
My Taco is a 2002 w/o manual hubs, so I guess ADD. (What does ADD stand for?)
I havent had the truck long, so havent had the opp to take it out and play/experiment/etc.
Im gatheirng from what you typed there "if im driving and shift back to 2WD i sometimes have to let off the gas or give it a quick blip to make it switch...........
..........if im at a stop and put it back into 2WD i sometimes but not often have to back up a tad then go forward to make it switch."
its trial and error. OK, I can live with that, but semi-predictability is nice.
Old 01-08-2004, 05:05 PM
AverysDad's Avatar
ADD.........automatic differential disconnect = no having to get out of your truck to turn the hubs, but it also means the half shafts(cv joints) up front are always spinning.
im pretty sure the ADD in the newer trucks is the same or very similar to the one in my 4runner. i never have an issue switching in or out of 4WD like i sometimes do with my taco/manual hubs.
Old 01-08-2004, 06:01 PM
TACOMANATOR's Avatar
I have a 2000 Taco and have never had a problem switching in and out of 4 wheel drive. As fast as I can move the lever its in or out.
Old 01-08-2004, 06:53 PM
cctk2's Avatar
ADD = Automatic differential disconnect. Thanks muchly.
Which leads me to the next question. The front wheel drive disconnects in the transfer case? Ok.
With the TLC, Ive always had the luxury of locking hubs. Free wheel the front axel the time till I get anywhere where theres a prospect of wanting the front drive on line. Then lock the hubs, and run in 2WD till the need for 4WD arises.
Ive read whats involved to retro these late model Tacos to accomodate locking hubs. (Believe me, I wish I had them on this rig.) After some deliberation, Im electing to NOT go out and find a wrecked Taco to part out then go through the headache to convert the 2002. Having been through the CV joint senerio (with Hondas), Ill just run with that mentality, and put up with the relatively insignificant lower gas mileage.
Remember one of the big reasons we buy Toyotas. In spite of some design flaws, theyre still pretty bullet proof!!
Chip
Attached Thumbnails Stop/reverse to disengage??-44magflash.jpg
Old 01-09-2004, 07:26 AM
Gbost's Avatar
I have an 02' with ADD and shift in and out of 4wd with no problems at speed without letting of the gas or anything
Old 01-09-2004, 07:36 AM
gtaSR5's Avatar
If you're on 4hi and you stop to park then shift to 2hi, is that ok? Does the 4wd disengage?
G-off
12-29-2015 12:44 PM
scheuvront1993
09-17-2015 06:17 PM
Scatterbrain
09-03-2015 06:46 PM
CanRunner
07-20-2015 01:29 PM
Nitro Hotpants
9
03-08-2004 10:49 AM
Quick Reply: Stop/reverse to disengage??
