Stock tie rod lengths?
Got a bent tie rod up front and I'm looking at replacing it with something that's got some strength to it. I figure might as well replace both while I'm up there. Looking at All Pro Off Road's tie rods, 43 1/4". I don't want to do the Hy-Steer setup, I don't wheel that much, but I want something that will withstand some heavy abuse. I KNOW it says that is the stock length, but with my luck I order it and for some f-ed up reason it's not right. Please help out!
Uh? Huh?
Is this for a truck not listed in your sig?
You cannot do hi steer on an IFS truck.
You have to special drill for the FJ-80 rod ends, which are what All Pro sells.
Not that hard, but just FYI. You will probably have to fabricate a new tie rod adjuster sleeve, as the FJ-80 ends are likely fatter than your current set up.
And this is why I post here! I wasn't aware of the hy-steer/ifs situation. Thanks for the help. I may just go for stock tie rods then.
Jcrawl94
10
10-24-2015 04:34 PM
