Stock intake with aftermarket K&N tube??
Old 10-28-2004, 03:16 PM
snwbrdpunk16's Avatar
Is there any way to make this work? i got the stock airbox back in place, but now im tryin to think of how to make the tube a bit shorter... any ideas??
Old 10-28-2004, 03:27 PM
mtxride's Avatar
I would say cut it with a hack saw then sand it down nice and smooth. lowe's and home depot has rubber couplers that look basically like the one that connects the FIPK tube to the throttle body... you can maybe use that to attach the tube to the air box.
but why not just use the stock tube with the silencer removed?? then you could sell the FIPK and maybe get a hundred or so dollars for it.
Old 10-28-2004, 03:31 PM
I might do that, i havent decided yet.
Old 10-28-2004, 05:27 PM
The whole stock intake is back on now, i will be doing the deckplate mod, and the remover silencer boxes and putting caps over the holes. Has anyone done this? not the deckplate, but the capping the holes? if you have done it, what did you use and how exactly did you do it?
Old 10-29-2004, 04:32 AM
Away
Dr. Zhivago's Avatar
Um...
https://www.yotatech.com/~corey/tech...ntake/dr_z.htm
https://www.yotatech.com/~corey/tech...r/96runner.htm
You MUST be new around here.
Welcome to the forums.
G
RatOmeter
10-22-2015 03:17 PM
09-04-2015 09:27 AM
adammtb
07-27-2015 11:57 AM
1994toyota
07-17-2015 03:03 AM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: Stock intake with aftermarket K&N tube??
