Stock Cooling Fan questions
Old 07-30-2010, 09:12 AM
Cbpcop's Avatar
Vehicle is 98 4Rnr w/2.7 liter 4 banger, 2WD, auto etc. (painfully stock). The issue is that the belt driven cooling fan NEVER disengages (unless it gets somewhere below 60 deg F). Location is south Florida, land of eternal heat. I've read on another forum about disassembling the fan clutch, cleaning it up and refilling with new silicone clutch fluid. Is this an effort that will be worthwhile or is it just too hot down here for that blasted thing to ever disengage? MPG is an average of 15-18 combined. Engine definitely has more power during cold weather with fan NOT running. Don't have the bones to buy an electric fan setup yet.
Old 07-30-2010, 09:17 AM
DailyDrive's Avatar
What do you mean by never disengages? It's supposed to spin all the time. The real question is, does it always sound like a plane taking off, or just when cranking it up cold, and then it quiets itself?
Old 07-30-2010, 09:21 AM
Cbpcop's Avatar
Nope! never quiets itself. Pretty much have to file flight plans just to go to work everyday - howls like a banshee!
Old 07-30-2010, 09:39 AM
PismoJoe's Avatar
Time for a new fan clutch
Old 07-30-2010, 09:44 AM
Cbpcop's Avatar
Guess the fluid change idea is probably a bust then? It's gonna really suck if I change the stupid thing and get the same result. This last "winter" we actually had temps down into the 40's and it "disengaged" ie didn't run all the time. Same diagnosis? - new fan clutch?
Old 08-02-2010, 05:28 AM
gdutch's Avatar
I live in Texas, and this summer my fan pretty much howls every time I take off from a stop. That said, it shouldn't be doing that all the time when it gets to be below 70* or so. You might be running hot, which is causing the ECU to keep the fan blowing.
Old 08-02-2010, 08:26 AM
PismoJoe's Avatar
The fan clutch is not electronic, it is controlled only by temperature. Depending on the temperature, the bi-metallic spring on the front will open and close an internal valve causing the clutch to spin faster or slower
Checking the fan clutch is really simple. When the engine is off and COLD, the fan should spin with little resistance.
Old 08-02-2010, 09:09 AM
DailyDrive's Avatar
Fan should spin with little resistance only when the clutch is at operating temperature.
Hence why the prop airplane sound when cold.
Old 08-02-2010, 09:44 AM
PismoJoe's Avatar
I think you have it backwards, you're saying that the fan SHOULD be engaged when it's cold then
Old 08-02-2010, 09:54 AM
TheDurk's Avatar
I have been bothered by this apparent inconsistency. Here is the answer:
A thermal fan clutch is engaged on a cold startup because the fluid drains into the working area when the engine is shut off. The fan clutch will slow down shortly after startup as a result of a pumping action produced by a difference in speed between the shaft and the body of the clutch.
Source: http://www.haydenauto.com/Featured%2...s/Content.aspx
The noise at start-up being there and then going away appears to be the best diagnostic guide to the health of your clutch. I am new to these things--my other cars have been electrics or old fashioned straight mechanical. Other keys are absence of evidence of fluid leakage and excessive lateral play at the fan blades.
Old 08-02-2010, 10:35 AM
PismoJoe's Avatar
Well I have 2 brand new Aisin OE fan clutches, one on my Tacoma and one on my 4Runner, its 65 degrees outside, haven't been ran today, and they are spinning with very little resistance when turned by hand.
Durk, you're right though, the fan should spin like that for a very brief few seconds at startup, but it should not be engaged fully like I perceived DailyDrive to be referring to. Maybe he meant for a few seconds, I could have misunderstood.
Old 08-02-2010, 02:09 PM
TheDurk's Avatar
Actually, I think I misunderstood YOU. Anyway, the question of why it engages at start-up is not obvious and I thought worth explaining. And yes, My new OEM Aisin fan does engage at start-up BUT it spins with relatively little resistance by hand--EXACTLY as did the non-functioning 11- year old OEM clutch I took off last week. I checked them side by side and the resistance to turning (cold, obviously as they were on a bench) was light and identical for both. I therefore assert that resistance to hand spinning is not a good method of judging health of your clutch, but start-up action is. My new clutch passed the acid test on the Delaware Memorial Bridge this weekend so I know it's good.
I guess if it was locked up when you hand spun it, or if it freewheels, you could say it was bad, but the fact that it spins with light resistance is no assurance that it is good...or bad....or anything.
Old 08-03-2010, 08:28 AM
profuse007's Avatar
My 2000 4cyl starts up like an airplane and slows down after 30sec or so. It spins like an airplane when I rev while driving.
Old 08-03-2010, 03:56 PM
Cbpcop's Avatar
Here's a new one: had a guy who claimed to have worked for Toyota for awhile (insert grain of salt here) tell me they used to do the fan clutch fluid refills using transmission fluid and had good results. I'm a box of rocks on this one guys - does this sound even feasible to anyone? I've been around long enough to know that just because someone does something doesn't mean it's going to work right.
Flying91
45
04-11-2024 04:39 PM
the1998sr5
15
07-14-2020 08:35 PM
coryc85
09-09-2015 06:24 AM
coffey50
07-28-2015 10:55 AM
jackiebrownia
07-20-2015 09:02 AM
Quick Reply: Stock Cooling Fan questions
