YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-13-2003, 06:14 AM   #1 (permalink)
PirateFins's Avatar
Send a message via AIM to PirateFins Send a message via Yahoo to PirateFins
Stock clutch fan question????
On the subject of fans. Can someone explain how the stock clutch fan works. Does the clutch engage to provide extra fan rpm's for better cooling? Or is it vice-versa? If it enganges to give higher fan rpm's, has anyone removed the fans clutch mech's to keep it from engaging? What I am trying to accomplish is...
It seams like everytime I am climbing a decent sized mountain on the hi-way, right in the middle the clutch engages and rob's my engine of power slowing me down (approx 5 miles per hour or more off loss). I want this to stop before I get run over. Every time I her it kick in I look at the temp guage and it isn't anywhere near hot (about 1/3 up on the eng temp guage). Let me know if it is possible to remove the clutch assy. By the way this is my Dly Drvr, that doesn't see much dirt.
Thanks
__________________
Brad
Work is for those who don't know how to plunder!!
Quote:
Originally Posted by habanero View Post
I'd experience an O so big it'd show up on the richter scale.
92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money!
04 F150 FX4 SuperCrew
PirateFins is offline
Sponsored Links
To remove this ad, register today!
Old 05-13-2003, 06:23 AM   #2 (permalink)
<96 Runner>'s Avatar
If I remember correctly, it operates by fluid exchange. As the fluid heats up, the clutch pack engages, causing the fan to "grab" the current pulley speed, thus increasing drag on the engine.
What you are feeling going up hills is the fan working as it should. I would caution you before you open it up and fiddle with it. But, should you choose to do so, and mess it up, I have 2 fans sitting in my attic.
__________________
Christian <><
My SC'd 4Runner's Profile
My YouTube vids
<96 Runner> is offline
Old 05-13-2003, 09:37 AM   #3 (permalink)
PirateFins's Avatar
thanks for the input. I read somewhere about a taurus elec fan fits nicely so I might look into that. Or just take mine apart and screw with it. If I mess it up I will take you up on your offer to clear out some attic space for you.
Thanks
__________________
Brad
Old 05-13-2003, 09:43 AM   #4 (permalink)
Shipping might be spendy, and I am not sure if the 3.4 fan will fit the 3.0. Just a heads up.
__________________
Christian <><
My YouTube vids
Old 05-13-2003, 10:19 AM   #5 (permalink)
4runner4ever's Avatar
Don't fiddle with the hydraulic clutch unless you want to mount a new head gasket.
As soon as you drain the fluid, the clutch doesn't work anymore and the fan is in fact mounted only on a bearing. It will only rotate at a low speed and will not cool anymore. The way to go is a good electric fan.
4runner4ever is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Question on fan clutch scrid 86-95 Trucks & 4Runners 0 11-12-2006 07:41 AM
Solid fan and remove fan clutch?? riceburner 84-85 Trucks & 4Runners 7 07-09-2006 05:55 PM
stock radiator fan w/clutch $15 4wd_mofo Engine/Tranny/Parts 0 05-03-2006 11:55 AM
Fan Clutch Question 3.0 V6 aNUT 95.5-2004 Tacomas & 96-2002 4Runners 3 03-15-2005 01:43 PM
need info on replacing stock clutch cooling fan w/ flex-a-lite RufusRunner 95.5-2004 Tacomas & 96-2002 4Runners 9 05-08-2004 11:50 AM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
