Stock 4.88's and 33's
Originally posted by my95toy
well the chart said they're 4.875. Is that a big difference gear wise from 4.88's? i wouldn't think so but i'm no mechanic
Re: Re: Stock 4.88's and 33's
Originally posted by BigBadBlue
So what does G294 mean?
G = 8" diff
29 = 4.10 gears
4 = 4-pinion diff
most likely on a heavy truck or something. no way you're going to be able to make a 7.xx gear run on an 8" diff. maybe something like a dyna or other big truck like that could have them available
i just found out that G144/ on my door panel means i got stock 4.8 gears. has anyone ran 33's with these?
I'm actually not even sure what kind of gears I have but I figured that since I had 31's on the truck when I got it that I have 4.88's on there...I'll check the stuff on my door panel when I get home to be sure.
Thanks,
Fink
Thanks,
Fink
Fink, my truck came with the factory 31 inch tire package too and 4.88 gears. 31's with the 4.88 are about the same as 33's with 5.29, both however are geared too high IMHO.
The best set-up I have run was 33's with 5.71 gears with the auto tranny. With that set-up the 3.0 could pull the OD gear quite nicely in the 65-85 mph range. The only problem was the 5.71 gears didn't hold up more that about 40K miles for me. So I'm running 5.29's now.
Originally posted by fooddude
dang blue you have 4.10s with 35's how well does your rig go.
Currently have 35s & an auto trans. Jumping it up to 5.29s from the 4.10s. Should be a lot quicker shouldn't it?
Originally posted by mt_goat
I bet you don't use your OD gear much with that huh?
i went to an offroad shop and the guy said he's seen some broken rear ends with 5.29 gears. he recommended 4.88 for 33's. although the peps on this forum haven't seemed to have had any problems with 5.29s
33's and stock 4.88's for 4 months or so now. I ran 32's for 85-90K miles with no problems. Although, MY 3.0 is a real powerhouse . It does just fine and its purty hilly here.
Blue
