sterio gurus
Old 03-30-2004, 05:11 PM
chasmc2's Avatar
Question sterio gurus
Im in the process of making a box for 2 ten inch woffers. My question is. should I make it a certain size box? I was thinking 8x14x35 then what is the best thing to do with the inside of the box
Old 03-30-2004, 05:28 PM
ElwayLite's Avatar
The paperwork your subs came with will state what kind of box(ported/sealed) and how large(0.75cu ft or 1.5cu ft). You need to build you box where your sub has the recommended enclosure and airspace. Also keep in mind, if you go slightly larger than recommended air space youll get more boomy bass, if you go lower in airspace you get tighter bass.
Old 03-30-2004, 10:55 PM
And make sure you calculate based on internal dimensions of the box, not external..
Old 03-31-2004, 04:28 AM
ElwayLite's Avatar
tru dat.
Old 03-31-2004, 11:58 AM
chasmc2's Avatar
I looked at the specs and there is nothing telling me what the size should be. im thinking of getting another 10 and put 2 6.5 subwofers plus the two tens. the box I was thinking of is 8x34x20.
Old 03-31-2004, 12:55 PM
ElwayLite's Avatar
Check the speakers website or do a search on google on the net, you really need to know the recommended app and volume.
Old 03-31-2004, 01:06 PM
Krash's Avatar
There is this program call WinISD made by linear team. You can get it here http://www.linearteam.dk/ . Play around with it, you can plug in the specs of your speaker that came with the subs and you can fool around with air spaces and looking at the plots to see what creates the best box for your subs. It takes a little bit to learn the program but well worth it.
Old 03-31-2004, 02:56 PM
chasmc2's Avatar
thanks ill give it a shot.
Old 03-31-2004, 03:19 PM
jrok's Avatar
if you are limited on space and hence internal volume you can also use polyfill inside the enclosure. it has the effect of making the enclosure seem larger than it really is to the driver, and it will generally tighten the sound by cancelling reverberation. from past experience I would think at least .75 cu. ft. per 10" driver.
Old 03-31-2004, 03:26 PM
Krash's Avatar
wow, someone else from louisville replied. Glad to see more people from ky joining the forum.
MadMax48
03-03-2020 10:33 AM
EatChipsNow
09-09-2015 01:25 AM
yaqui
09-25-2007 09:18 PM
Quick Reply: sterio gurus
